Author Topic: Building the Schaarhörn  (Read 1278 times)
awvs
« on: November 09, 2020, 02:59:38 pm »
A couple of month ago I bought a kit of the steamship SCHAARHÖRN made by Caldercraft. The kit contains a fiberglass hull, many laser cut wood sheets, about 800 white metal parts, etched brass parts and three plans with very limited instructions.
So far I worked mainly on the hull. I added the drive shafts and two 775 motors, the basic electrical wiring, painted the hull and added some of the deck features. Reading some of the older build logs, this model seems to have, thanks to the weight of some of the white metal parts, a very high center of gravity. I added approximately 2kg of lead in the bottom of the hull and I will replace some of the heavy white metal parts with some plastic items. I will post a few more pictures as soon as there is some progress on the superstructure.
Wilhelm
Mark T
Re: Building the Schaarhörn
« Reply #1 on: November 09, 2020, 04:59:59 pm »
Very nice and the electrical installation is so tidy - lovely job  :-))
radiojoe
« Reply #2 on: November 09, 2020, 07:00:37 pm »
Beautiful hull and an excellent installation of the running gear, look forward to your progress.  :-))
Joe.
awvs
« Reply #3 on: November 09, 2020, 10:52:44 pm »
Thanks guys, much appreciated.
Wilhelm
    • Dave's Hobby Workshop
« Reply #4 on: November 10, 2020, 07:50:49 am »
The layout of the RC equipment is very neat and the whole thing looks very good
Thanks and regards
And if the band you're in starts playing different tunes...
awvs
« Reply #5 on: November 10, 2020, 10:00:06 pm »
Thanks Dave for your kind words.
Wilhelm
Mike S
« Reply #6 on: November 11, 2020, 07:29:48 pm »
Excellent electrical installation, you obviously follow the maxim 'neat wiring is reliable wiring'.
Cheers,
awvs
« Reply #7 on: November 11, 2020, 10:19:58 pm »
Thanks Mike.
In a fairly tight space, the hull is long but very narrow, you can't fool around. I always watch my electrical layout and reliability. I also make individual schematics for every model I build. For the fun of it I do attach the diagram for the Schaarhörn.
Wilhelm
Rmay
« Reply #8 on: November 15, 2020, 02:30:04 am »
Wow! The electronics are so well laid out. As are all your builds. Almost as beautiful under the decks as above.  :-))
awvs
« Reply #9 on: November 15, 2020, 01:49:09 pm »
Thank you very much for your special comment, much appreciated.
Wilhelm :-)
awvs
« Reply #10 on: November 19, 2020, 10:41:10 pm »
Here is some progress on the superstructure. I finished the anchor winch, painted most of the superstructure and worked on the state room. The furniture isn't quite to scale, 1:30 instead of 1:35. I added also a false ceiling with LED lights and the cut out for the skylight. In order to get easy access to the electronics I did split the state room from the main structure.
Wilhelm
« Reply #11 on: November 20, 2020, 01:11:07 am »
So Wilhelm......I like the build   :-))
You appear take the power supply from the Port motor 'speed controller', as a convenient source on the unregulated side? for the single Blower Fan Motor
 These smallish Pillow Fans will work in dissipating xx units of heat as measured in a reduced thermal gradient of the external motor casing temperature, however needs careful consideration
 We also see that this motor in manually switched......however is the fan blowing air downwards?, or drawing heat/air from the motors casings to atmosphere?
If it is the latter, you could consider some light styrene sheeting to make an exhaust trunk over the fan square body upwards to atmosphere via a vent placed on the external face [companion-way] on deck level. Naturally whatever volume [FAD] of the fan must also be complimented as a ‘greater’ availability of free volume of air entry
If the fan were reversed, it would simply circulate warm air within the hull and superstructure  >>:-(
Honorary Secretary
awvs
« Reply #12 on: November 20, 2020, 04:47:01 am »
Hey Derek,
thanks for your information on air flow.
For your information, the fan is blowing air over the motors. Right above the cooling fan are four openings (windows) in the superstructure where the fan can draw fresh air. The circulating air will also cool down somewhat on the wall of the hull which is surrounded by cool water. Furthermore some of the warm air can also vent through the  funnel and another three openings in the ceiling of the superstructure. It should be okay. The first test run in my pond will tell me whether the fan is even necessary. If heat will be a problem I will build a contraption from the four windows to the fan.
I assume that the air circulation will be a minor problem compare to lowering the high center of gravity to a more reasonable level.
Wilhelm
Daleb
« Reply #13 on: November 27, 2020, 10:34:02 pm »
How's the build coming on Wilhelm, looks great so far.
Dale.
awvs
« Reply #14 on: November 28, 2020, 02:42:19 pm »
Hi Dale,
I managed to make some parts for the upper deck of the superstructure, started the railing and the funnel got a new top made out of plastic. I did find a picture of the stain glass skylight and added it too. Most of the parts in the pictures are still not mounted because I want to finish the lighting for the deck first and the LED's haven't arrived yet.
Wilhelm
Daleb
« Reply #15 on: November 28, 2020, 03:22:09 pm »
Looks fabulous Wilhelm :-))
awvs
« Reply #16 on: November 28, 2020, 10:45:33 pm »
Glad you like it. :}
Christmas preparations are taking over and the next update might take some time.
Wilhelm
Martin [Admin]
« Reply #17 on: November 29, 2020, 10:08:20 am »
Yes, wonderful!   :-))
awvs
« Reply #18 on: November 30, 2020, 12:44:04 pm »
Hey Martin and thanks for your kind words, much appreciated. :-)
Wilhelm
hama
« Reply #19 on: November 30, 2020, 02:04:56 pm »
Never mind about Christmas, keep on building! {-)  Joking aside, she looks fabulous and you're doing a great job. :-))
Hama
awvs
« Reply #20 on: December 02, 2020, 01:05:39 pm »
Thanks Hama :-) . Good advice but I just can't skip Christmas  %)
Wilhelm
awvs
« Reply #21 on: January 17, 2021, 04:56:59 pm »
Hi guys,
as you can see in the attached pictures, I did finish the Schaarhörn. I did add a rotating radar screen, extra lighting, depth markers and a sound module (RAM steam whistle).
I hope you enjoy the pictures.
Wilhelm
« Reply #22 on: January 17, 2021, 05:02:41 pm »
Magnificent an excellent piece of work you are to be congratulated  :-)) :-))
Steve Mahoney
« Reply #23 on: January 17, 2021, 08:09:46 pm »
Wow – that turned out really well. Great work.
awvs
« Reply #24 on: January 17, 2021, 08:15:08 pm »
Thanks Phil and Steve for your nice comments., much appreciated.
Wilhelm
