Author Topic: Building the Schaarhörn  (Read 2550 times)
Re: Building the Schaarhörn
« Reply #25 on: January 17, 2021, 08:37:10 pm »
Wilheim.......
In certain cases, anti-rotation spikes with a 'drop-down' ends were uses between pairs of turn buckles.......easily adjusted, although for  standing or fixed rigging the requirement for adjustment is low.....however natural vibration & under tension, can cause rotation
Small lengths of galvanised wire rope were also used, although could look a little out of keeping on a vessel of this style or Class
awvs
« Reply #26 on: January 17, 2021, 08:46:00 pm »
Thanks Derek,
that makes sense. Maybe a thin spring loaded split pin, for easy removal, might do the trick. I will look into it.
Wilhelm
« Reply #27 on: January 17, 2021, 09:48:23 pm »
Yes, make sure it is tidy & not to be a scratch hazard as unbroken wire rope could be  <*< .....were all of the Turnbuckles & fastners included in the kit?, or did you purchase them?....Knupfer??...excellent product & people
Maybe a drop of Loctite 243 on each of those M2 brass bolts & nuts.......[easily removable with standard spanners, but will never vibrate loose]
[The Knupfer 3,0 SW [or 3 AF] OE spanner is the standard size for the M2 bolts & nuts] - [10BA is ~~ the same AF size, but the spanners are x 1.5 the head thickness & head diameter]
Seacommander
« Reply #28 on: January 17, 2021, 09:55:38 pm »
What great example and such wonderful work
I always hung my nose over this boat, but I could never do what you have
Just brilliant, very inspirational
Love to see some pics on the water
Congratulations on a great build
Thanks for sharing
awvs
« Reply #29 on: January 17, 2021, 10:36:09 pm »
@Derek,
the M1.4 fasteners and turnbuckles were included in the kit. Too bad that the turnbuckles were made of white metal and for this application definitely useless. The fasteners were of good quality. I did buy the brass turnbuckles from "prime-miniatures" in the UK. Great service and product!
@Seacommander,
thanks for your kind comment. I will post some pictures of her in the water but it won't be before ice out by middle or late April. :((
Wilhelm
awvs
« Reply #30 on: April 11, 2021, 03:21:41 am »
Hi, this week was the maiden voyage. Everything went well and she really shines on the water. The location of the ballast ( in correlation with the center of gravity) seems to be spot, no problems even in faster turns. I hope you enjoy the pictures.
Wilhelm
radiojoe
« Reply #31 on: April 11, 2021, 06:36:01 am »
She looks impressive Wilhelm beautiful build.
Joe.
kevin547n
« Reply #32 on: April 11, 2021, 09:41:42 am »
what a lovely build
Amerigo Vespucci -  Panart - 1/84
https://www.modelboatmayhem.co.uk/forum/index.php/topic,66456.0.html
I tend to do a lot of building at the weekends, then ponder what i have achieved during the week, then adapt, redo or accept the following weekend
Daleb
« Reply #33 on: April 11, 2021, 12:47:54 pm »
Fabulous build Wilhelm, she looks stunning on the water :-))
Dale.
awvs
« Reply #34 on: April 11, 2021, 04:07:22 pm »
Thanks guys, I really appreciate every comment from you. :-)
Wilhelm
Seacommander
« Reply #35 on: April 11, 2021, 05:17:29 pm »
Wonderful !!
It's my birthday today, great present to see your model finally on the water
Many congratulations, job very well done
Thanks for sharing
Mark
awvs
« Reply #36 on: April 11, 2021, 06:59:13 pm »
Happy Birthday Mark.....and many more! :-)) :-)) :-))
Thank you also for your great comment.
Wilhelm
