Author Topic: Miniature Wood Plane Review  (Read 1527 times)
Mark T
« on: November 14, 2020, 02:21:11 pm »
I’ve been meaning to write a review of some miniature planes for a while just to help anyone out who’s thinking about buying one.  I personally use planes quite a lot now instead of sanding down.  I find that they give a much nicer finish and create a lot less mess as its easier to hoover up shavings rather than dust.  Here’s a review of three planes of varying prices and capabilities.
Vertias Miniature Block Plane
This really is a tiny little plane that fits in your finger tips.  Its beautifully made and has a cutting angle of 37 degrees so its capable of cutting end grain too.  It has a Norris style blade adjuster which makes blade adjustment easy and weighs 48 grams.
So is it a toy?  No!  This is a very good piece of kit for model making that can take off the finest shavings.  It can also take quite a deep cut too and is very sharp straight out of the box.  Because you hold it with your finger tips it really has a nice feel to it.
The down sides are that it has a very small foot print so it does take practice to learn how to use.  Its easy to create a wavy cut if you don’t either hold it or the work place tightly.  You must also be very careful not to over tighten the Norris adjuster as it will damage the shoe.  I did this after owning it for a couple of years so I had to contact Veritas for a replacement.  They sent me one free of charge from Canada now that’s great service!
The current price of this plane is £47.88 and if looked after will last a lifetime.
Lie Nielson Violin Makers Plane
Wow this is a nice tool;  its one of those tools that you own that’s even nice to just look at.  The first thing you notice is the weight of it.  Boy this is a heavy little tool for its size as its made of bronze.  It just says quality and and the blade adjuster is extremely precise.  This plane will fill the palm of your hand and it fits perfectly and weighs 227 grams.
This is a professional tool that will take anything from the finest cuts to some really deep ones.  This plane can really remove a lot of material if you need it too without any blade chatter.  Its surgically sharp straight out of the box and would you believe the cardboard boxes that they come in are collected by some people.  I sold my box on Ebay for just over £10!
The down sides are it is a heavy little tool which can sometimes be a pain when trying to remove tiny passes.  The weight removes some of the feel of what you are doing.  The cost….this is a very expensive tool which is out of range of many model makers.
The current price of this plane is £112.28 but you could pass this down to your kids in your will its that well made.
Veritas Miniature Bench Plane
Another lovely plane from Veritas which has the same adjuster as the block plane.  Its really beautifully made and has a cutting angle of 38 degrees.  This plane weighs 64 grams and is used by clamping the workpiece and using it with both hands.
Once again this is not a toy its really is a good plane but it does a different job.  The foot print is much longer and is fantastic for finishing off and smoothing flat surfaces.  Its sharp straight out go the box and it feels nice to use; once again it held in your finger tips.  Its easy to keep a nice straight cut with due to its length and gives a very nice clean finish.
The down sides are its not as versatile as the other two planes.  Its better at giving a finished surface over a bigger area but with practice a guess its could probably do well.
The current price of this plane is £52.88 and again if looked after will last a life time.
Conclusion
So if given a choice to only have one which one would it be.  I would choose the Veritas miniature block plane.  I have found it to be a fantastic little plane that has loads of quality for the price.  It's so easy to use and has a very short learning curve to master.
I know that there are some very versatile cheaper planes available but I’ve never used one so I can’t review them.  I hope this review helps someone
SailorGreg
Re: Miniature Wood Plane Review
« Reply #1 on: November 14, 2020, 05:04:57 pm »
Thank you for that Mark, very illuminating.  I have a Lie Neilsen block plane which is my go-to plane for small jobs, full size and modelling.  Yes, it is on the pricy side but it keeps its edge for ever - can't remember when I sharpened it last!  I do have a couple of smaller planes but they are of uncertain parentage and I keep pondering a good quality small plane.  Good tools are just so much nicer to use.  I can see the Veritas miniature block plane appearing on my Christmas list.  Thanks again.
Greg
Mark T
« Reply #2 on: November 14, 2020, 06:44:13 pm »
Thanks Greg  - There are so many so called modelling tools that make the job harder than easier.  I know because I've bought and thrown so many away which is why I did this post.  Lie Nielson are just amazing tools but so expensive.  It would be great if others could post their experiences of other planes too.  We need to share our experience to help others.  If you do get the Veritas block plane for Xmas you won't be disappointed :). My Bench plane was bought by my wife for me without me knowing just by the way I spoke at home about the block plane!  I'm a lucky man!
Jerry C
« Reply #3 on: November 15, 2020, 12:09:22 am »
I used the left hand one on here but with Rolson name to great effect on SLWear
https://www.ebay.com.au/itm/163508841244
Jerry C.
« Reply #4 on: November 15, 2020, 09:26:30 am »
  I have both the Veritas miniatures and find them very nice and always reaching for them, the little hinge lid boxes are good for keeping them on the bench but protected . They are though both a bit fiddly when sharpening the very small blades and re-setting them up precisely for use , particularly if you have fingers like pork sausages.
Mark T
« Reply #5 on: November 15, 2020, 10:23:49 am »
Hi Baldrick - Veritas now make a honing guide especially made for the small blades
https://www.axminstertools.com/veritas-miniature-honing-guide-mk-i-106746?glCountry=GB&glCurrency=GBP
« Reply #6 on: November 15, 2020, 10:33:35 am »
 Thanks Mark.
                  Oh well, there goes another £39.48
NickelBelter
« Reply #7 on: November 17, 2020, 11:39:41 am »
Veritas also makes a right-angle plane which I find indispensable for putting right angle edges on styrene sheets (makes it easier to turn out square superstructures without gaps. It's the farthest on the right in this pic.
