Author Topic: Max Hemmens engine history.  (Read 2432 times)
KBIO
« on: November 15, 2020, 10:40:07 am »
Hello!
I am looking for a maximum on pictures and informations about the MH engines.
I'd like to know the difference between the CATON and the MAX II and more !
Below are 2 photos.
The  first one is believed to be CATON with driven feed pump.
The last one is supposed to be a MAX II.
Your help is appreciated.
Regards.
KNO3
Re: Max Hemmens engine history.
« Reply #1 on: November 15, 2020, 02:51:47 pm »
Please post some close up pictures of the Caton engine.
KBIO
« Reply #2 on: November 15, 2020, 03:35:16 pm »
Hello!
It's going to be tough as it is in the boat.
I see if I get something better with a good light!
Cheers.
pipercub1772
« Reply #3 on: November 15, 2020, 08:52:35 pm »
That's certainly the caton engine in the model launch and hemmings Max 2 both fine engines will last a lifetime if looked after ,
KBIO
« Reply #4 on: November 16, 2020, 02:53:17 pm »
Hello!
Here I am back again with my questions.
Below are two Max Hemmens engines.
The RED one has top cover with a diameter of 20 mm.
The BLACK one is a bit smaller and has a diameter cover of 18 mm
Question:
- Can someone tell me which one is the Caton and which one is the MAXII ??
    It looks easy as the RED one is stamped MAX II and the BLACK one has no stamp or mark on it. But confirmation is welcome.
- The other question and the most important is : Is there other M.Hemmens engines and can I have photos and descriptions, please.
Any answer will be of interest !
Best regards.
tonyH
« Reply #5 on: November 16, 2020, 03:21:55 pm »
I bought a machined kit for one of these from MH years ago for £80.00, put it in a large Saint class salvage tug with a 4" Cheddar boiler and it was absolutely brilliant.
ooyah/2
« Reply #6 on: November 16, 2020, 05:53:14 pm »
Hello!
Question:
Best regards.
Yves
I would go with the red one that has MAX 11  on the slide valve chest, or is that too easy.
George.
KNO3
« Reply #7 on: November 16, 2020, 06:11:04 pm »
Hello Yves,
The black engine is the Hemmens Caton, with 3/8 x 5/8" bore and stroke (9,52 x 15,87 mm). Engine height 3 1/2" (89 mm).
I have seen Caton engines also painted green by the manufacturer.
Obviously, the red engine is the Hemmens Max II - it says so on the label. It has 9,5 x 15,8 mm bore and stroke. Engine height 95 mm. Operating pressure 30-80 psi. Recommended propeller size 4 blade 76 mm.
The Caton is the older engine and I think it evolved into the Max II, which seems to have replaced it, having more features such as integrated lubricator cups with pipes for the crossheads. Bore and stroke seem identical and both engines have piston valves and a piston reverser. The Max II is however somewhat taller and has the pump mounted vertically at one end. The Caton could also have a pump, but was mounted horizontally to one side.
KBIO
« Reply #8 on: November 17, 2020, 07:33:27 am »
Hello!
Thank you gentlemen for those precious informations.
I did not know the one that TonyH presents. Tony, if can give the diameter/stoke of it, I would appreciate.
if someone knows something about this manufacturer , please, let me know.
have a good day!!.
tonyH
« Reply #9 on: November 17, 2020, 10:25:44 am »
This should give an idea. I honestly cannot remember, after all it was 20 years ago at least!
www.stationroadsteam.com/maxwell-hemmens-york-twin-cylinder-marine-engine-stock-code-348/
Page created in 0.098 seconds with 22 queries.
