Most important to this restoration is a working boiler, if the boiler is not right (size, capacity) or is faulty then this boat would be going no where. The boiler came supplied with a burner although it was laying loose near the boiler, see photo, its installation was obviously incomplete. So whilst the boiler looked in good condition I removed it from the boat to begin checking it over. The boiler usefully has the working pressure stamped on it at 80psi. The boiler contained some water so drained it off and then began to fill the boiler to find its capacity, a healthy 1.4 litres. With the boiler out of the boat I carried out a more detailed visual inspection, the main fire tube, 2 inches in dia, looked clean and most important was dry. I removed the end cover to check the steam dryer and cross tubes, then reassembled. It looked to me as though this boiler has never been fired, it looked very clean inside. To move on further I needed to pressurise the boiler to check for leaks, I did not have a pump to hand, so with it being full to the brim of water I thought about apply some gentle heat to bring up the pressure very slowly. I then turned my attention to the burner, it has type 40 stamped on it, I have no idea what that means? Anyway I needed to know a few things about the burner, whether worked and where in relation to the fire tube to place it (inside, level with, or outside) so a great chance to do some practical experimentation. With this in mind I set up the boiler on a bench in the garden. First I lit the burner!!!! Wow was not expecting that, as friend said, the flame would not look out of place beneath a NASA Rocket.
