Pages: 1 2 3 4 5 6 7 8 [9]   Go Down
Author Topic: Torpedo Boat Destroyer, HMS Daring, Stuart Sun steam Engines (restoration)  (Read 38358 times)
The propellers appear to be soldered, so as JimG questions ...'would it be possible?' to increase the pitch of the blades
Propellers for steam often have a ratio approaching 1.5 pitch to diameter...the propellers fitted to the vessel appear to be in the order of 0.7 pitch to diameter
Constructing a simple wooden jig to hold or clamp 'a single blade', then used in conjunction with a fixture [bench vice] could provide a relatively uniform adjustment to the pitch of each blade
An increase in pitch would place a greater load on the engines, reducing the engines speed, increasing thrust and running time
DBS88
It would be interesting to know what the pitch of these props actually is; is there a way to find it out?
As it happens I have a four inch, four bladed Prop Shop, prop so have taken some photos of it besides HMS Darings 3 Blade props, this may or may not help the discussion about the pitch of the current props. How does its pitch of the 4 inch prop compare with the current 3 1/2 inch props?
DocMartin
She looks fab on the water! Small scale steam does seem to be a great challenge that exercises the hobby, A chap wrote a series of articles in Model Boats back in the day where he built a metal model of Dreadnought and then installed dental drill air motors to use as steam turbines! I recall these having promise, but lacking power due again to lack of steam flow/pressure. I don't know how he got on as the articles were written about eight years ago.
Geoff
I have all these articles and it was a very interesting and valiant attempt and an interesting concept using dental drills. I seem to recall whilst he got it working the steam consumption was high and he had to start them with a drill as they were not self starting. I suspect the internals of a dental turbine are very different from a steam turbine.
Back to the TBD - if you have a prop shop prop would it be possible to fit it on one side and see if produces more or less thrust/speed. It would then give a direct comparison under identical circumstances which may provide some guidance. If its on the port side and the model turns to starboard then it would suggest more thrust.
A friend of mine commented that the "Sun" engines are best suited for high speed so a smaller prop and higher revolutions may give a better result, trouble is if you go that route the steam consumption will be higher. I always think of a boiler as having so many "bites" of steam so if you use them slowly you get duration, if you use them fast you get speed but less duration!
I look forward to the next instalment with interest. Very well done indeed.
Geoff
Pages: 1 2 3 4 5 6 7 8 [9]   Go Up
Page created in 0.2 seconds with 17 queries.
