I started to take apart some of the pre-glued cabin assembly last night.......not the best result !
The liteply is very weak and was quite happy to fall apart. This was especially tricky where the cab sides met the front and rear window screens where the glue was clogged very thickly in the corners.
The two halves of the cabin tops came away reasonably well, but I think the best thing I can do is to make a copy of the parts by drawing around them on the customary cereal packet cardboard before I loose any of the shapes as the wood falls apart.
This is bit too late for the rear screen (!) so I will be patching the pieces together today to make a card template from them.
One thing that I have noticed is just how big the front and rear cab windows are when compared with the Swordsmans front screen. The occupants inside must have had more vision from inside a Huntsman than they would have had if they were inside the cabin of a Swordsman.
I am already thinking about changing the cab sides to those of the open cockpit type, but I don't know what cab options were made available on the Huntsman 31 hull - but I bet somebody on here does
