good morning!
Thank you for your kind comments.
To answer to Steamboat model:
- The gas which is common 70 Butane/30 Propane is not vaporized IN the burner but AROUND.
A quick drawing below shows the path of the gas.
- It is taken from the bottom of the tank (10 mm above to avoid draining debris) . The top gas tank pressure pushing it out.
- It is "vaporized" in the coil around the burner.
- Then cooled down through another coil to bring it to ambiant temp to pass through the different devices (gas attenuator, regulator, shut of valve,.. )
Pinching this pipe between two fingers is enough to know if it's too hot or too cold. The coil length has to be adjusted then.
Note: The shut off safety valve has to be positioned on the gas side as it takes some time for the liquid to expand.
: we can see the cool down coil above the two burners in the previous photo.
Remember that a drop of liquid is 270 times its volume when gazeous @ standards conditions. So the gas tank never frost.
Some people add a second line 100% gaseous to warm up the burner prior to by-pass on the liquid line; I don't! I just crack the supply valve open until the burner is hot enough. It takes 10 second maximum. Then, it is not necessary to wide open it!
Note: never largely open the tank valve directly as the liquid will flow to the burner and make a flame thrower.
In Toronto, during the cold , I guess that the percentage of Propane is higher!
As I say : "do not fill up with butane in winter and propane in summer , or take a pack of beer with you to pass the time !"
Eventually, we may open a post on this subject if interested!.
Have a nice (an safe) day!
