I have a good bit of info to refer to now, thank you Bob.
So this week if time allows, I'm hoping to do something with the removed prop shaft holes and get those blocked off, filled and sanded back.
I also plan to cut out some cardboard templates that I can offer up against what is already there. Then I can try and work out how drastic the surgery on the Rover will be.
Whether I attempt to remove the sides completely and fit new ones completely or cut them down to deck level and butt the new sections on top, I'm not sure yet.
I also need to inspect the remaining centre shaft and make sure it is serviceable. If not, that's more surgery
I am looking forward to making a proper start on it, but I'm also a little apprehensive too
Once I start though, A, I'll have no choice but to carry on and B, once it starts looking a little less unloved, damaged and getting some shape back to it, that will boost both my enthusiasm and confidence.
Will
