Thanks for all of the advice and comments lads
Now - Disaster
I knew this would happen at some point and I guess its better to happen now than later. Today I was going to make the last two parts of the rising wood and finish the keel assembly. I thought that I had best check again the work that I had done and found a big error.
Now the thing thats troubling me is I'm not sure how this has happened. I placed my work on the plan like I have many times before and the stem is completely wrong. Its 1.65mm out of kilter which is way too much to carry on or correct. Its a bit like building a house with un-level foundations so I need to stop before going any further.
The last time I placed the keel on the plan it was correct and now it's not? I think I may have over clamped the apron and bent the stem but I'm unsure. Here's a picture of the problem.
This cannot be fixed
So the keel is scrap now as too much going forward relies on this being absolutely spot on.
So it's been sitting in a bath of IPA to try and salvage some of the parts but so far nothing's budged. My joints are possibly too tight for the IPA to do its job and separate the individual parts. I'll let you know how I get on but it looks like a full keel rebuild at the moment.
Hey ho - these things are sent to try us - but its got to be right
Leave it with me and I'll keep you posted. Luckily I have a good wood supplier
