Pages: [1] 2 3   Go Down
Author Topic: OUR LASS III  (Read 9128 times)
chipchase
OUR LASS III
« on: December 15, 2020, 10:22:01 pm »
 Hi all, along with my other two builds I am also doing a bit on my shelter deck trawler the Our Lass III, so I have decided to start a thread on the trawler I have had the hull for quite a while know she is 35 inches long with a beam of 10 inches she is 1/30th scale . I posted a few photos of the bow thruster that I made over the last few days on my Stevns Arctic build, today I have fitted the main drive shaft and the motor mount. I  decided to use a belt drive as the shaft is quite low, have test run the set up and i am really pleased with how smooth she runs.
chipchase
Re: OUR LASS III
« Reply #1 on: December 15, 2020, 10:24:05 pm »
A few photos of the drive set up
spearfish99
Re: OUR LASS III
« Reply #2 on: December 16, 2020, 11:08:47 am »
Watched this being built in Whitby as the holiday let we use is virtually next door to the Parkol yard.  Built on a flat quayside and then launched by the most enormous mobile crane ( which uses another huge mobile crane to assemble it!)   Launching is quite a thing.
 You might find these interesting    [size=78%]Our Lass III - Yard No 030 - Parkol Marine Engineering Ltd[/size]
Victory Rose - Yard No 037 - Parkol Marine Engineering Ltd
chipchase
Re: OUR LASS III
« Reply #3 on: December 16, 2020, 06:10:12 pm »
Thanks I have quite a few photos of the vessel as I contacted Parkol Marine who were more than helpful
Howard
Re: OUR LASS III
« Reply #4 on: December 16, 2020, 08:48:18 pm »
Hello Brian,
 Can i ask where you got your belt drive bits from please am thinking its the way I'll go when making my Hendon, Northsider, and Tynesider I will be using the same motors  Mobile marine T12's do you think they'll have anoght grunt.
               Regards Howard..
chipchase
Re: OUR LASS III
« Reply #5 on: December 16, 2020, 09:36:58 pm »
Hello Brian,
               Regards Howard..
Hi Howard, I bought the belts and pulleys from www.mfacomodrills.com I have used them before in other builds  :-))
I think the T12s will be ok they seem to have plenty of torque
Brian
chipchase
Re: OUR LASS III
« Reply #6 on: December 16, 2020, 09:47:05 pm »
Today I made and fitted the port and starboard keels, I fitted them the same way as fitted into my Stevns Arctic and Research LK 62
if it works don't try and fix it  :}
chipchase
Re: OUR LASS III
« Reply #7 on: December 17, 2020, 08:17:46 pm »
Bow thruster fitted today
chipchase
Re: OUR LASS III
« Reply #8 on: December 19, 2020, 08:38:55 pm »
Got the rudder and shaft parts made.
Mark T
Re: OUR LASS III
« Reply #9 on: December 19, 2020, 08:54:43 pm »
Wow thats some nice work going on there - that bow thruster looks amazing.
chipchase
Re: OUR LASS III
« Reply #10 on: December 19, 2020, 11:04:30 pm »
Thanks Mark.
Brian
chipchase
Re: OUR LASS III
« Reply #11 on: December 20, 2020, 08:28:12 pm »
rudder primed and fitted
Howard
Re: OUR LASS III
« Reply #12 on: December 20, 2020, 08:57:08 pm »
Hello Brian,
 I never thought any one would ever make model boat building sexy to watch but you do you keep me wanting more.
               Regards Howard.
chipchase
Re: OUR LASS III
« Reply #13 on: December 31, 2020, 07:55:04 am »
Still here just to cold to work in garage, managed to get a bit done. Started fitting deck frames and fitted port and starboard ladders
chipchase
Re: OUR LASS III
« Reply #14 on: January 07, 2021, 10:04:16 pm »
A bit more done on the Trawler
chipchase
Re: OUR LASS III
« Reply #15 on: January 22, 2021, 09:59:39 pm »
This is one of a pair of net drums that I made for the trawler, not the best weather for painting.
chipchase
Re: OUR LASS III
« Reply #16 on: January 30, 2021, 07:49:15 pm »
More progrès on the shelter deck net drums.
Howard
Re: OUR LASS III
« Reply #17 on: January 31, 2021, 12:18:10 am »
Great Work Brian, do you use do plastic or acrylic. for your rudder and motor mounts.
                  Regards Howard.
chipchase
Re: OUR LASS III
« Reply #18 on: January 31, 2021, 07:23:56 pm »
                  Regards Howard.
Cheers Howard
I used 5mm perspex for the motor mount, the rudder mount is alloy, hope this helps.
chipchase
Re: OUR LASS III
« Reply #19 on: January 31, 2021, 07:25:42 pm »
A bit more work done on the shelter deck
chipchase
Re: OUR LASS III
« Reply #20 on: February 03, 2021, 09:49:43 pm »
A bit more done on the shelter deck
Howard
Re: OUR LASS III
« Reply #21 on: February 03, 2021, 11:19:29 pm »
How do you do it Brian even your wood looks scale looking amazing friend.
    Regards Howard.
chipchase
Re: OUR LASS III
« Reply #22 on: February 04, 2021, 08:20:41 am »
Thanks Howard I managed to get a few photos showing parts of the deck floor, the planks I have made should be smaller but it looks ok and a lot of the detail that I have built into the shelter deck will hardly be seen but I know that the detail is they're. I am quite enjoying building her she is just a nice size, easy to move around instead of hiring a crane. I think I am finished with big heavy models, at 73 its starting to show  {-)
chipchase
Re: OUR LASS III
« Reply #23 on: February 05, 2021, 06:40:34 pm »
A bit more done on the hull detailing port side, cooling water intake and outlets made and fitted.
Taranis
  • Balne Moor MBC
Re: OUR LASS III
« Reply #24 on: February 05, 2021, 11:23:04 pm »
Lovely detail Brian.
ANDY
Pages: [1] 2 3   Go Up
Page created in 0.101 seconds with 21 queries.
