Author Topic: new accessories Deans Marine  (Read 1691 times)
Dean's Marine
    • Dean's Marine
« on: December 17, 2020, 12:51:12 pm »
 Hi Modellers
 I thought that you might like more news from the edge of the world near Farcet and to let you know the latest news from DEANS MARINE.
A new range of shafts added to our accessories range
PR-3
160mm x M4
Bright steel 160mm heavyweight tube fitted with BRASS sintered bearings at both ends.  The outboard end of the tube has a moulded hard nylon skeg fitted onto the tube
The steel shaft is a M4 thread, the inboard carries a reverse locking collar and a nylon oiler unit is also attached
The shaft is extended to 2.5" above the tube length and is of 4mm dia.  This unit is ideal for fast hulls when a serious amount of power is needed to be passed through the shaft.
PR-26
  80mm x M4
80mm TUBE / 130mm shaft with built in oiler
M4 thread with lock nut and locking collar.
PR-8
120mm 2mm x M4
Bright steel 120mm lightweight tube fitted with BRASS sintered bearing at the both ends of the tube and has a moulded hard nylon skeg fitted onto the tube, a nylon oiler unit is also attached with a locking collar
            The steel shaft 2mm steel with  threaded M2, 150mm long.
PR-9
20mm x 2mm x M2
Brass 120 mm tube fitted with BRONZE bearing at the prop end, and bronze bearings at the inboard end.
The steel shaft is a 2mm threaded M2 fitted for the prop end
2mm plain shaft at the inboard end and carries a oiling cup a reverse locking collar.
The outboard end of the tube has a moulded hard nylon skeg /bearing holder fitted onto the tube
PR-29
200mm x 2mm x M2
slim line tube 200mm  steel shaft 240mm
threaded M2
Bronze bearings
Oiling cup fitted with locking collar.
PR-28
150mm x 2mm x M2
Slim line tube 150mm  steel shaft 2mm x 180mm
threaded M2
Bronze bearings
Any further information see our website or online shop
 Dean Marine
 We wish you all a very merry Christmas , at least 2-3 nice sailing days over the holiday, and a healthy and prosperous new year
