Author Topic: Sea Raven  (Read 8215 times)
zooma
  • Never too old to learn !
Re: Sea Raven
« Reply #25 on: February 01, 2021, 11:35:41 am »
Hi Harry,
Sorry your thread has been a little hi-jacked and drifted off-subject from your excellent Sea Raven build, but I think it started with Leaky seeing a resemblance to the Beachcomber and me thinking that the Beachcomber was a bit like a sleek Vivacity etc... and as is often the case one thing led to another - it was very interesting - but to get back to your build:-
What have you got planned for the square hatch opening in the cabin roof?
A cabin roof light, ventilator,  or a space for a plug-in mast perhaps?
Looking forward to seeing it on the water!
Bob.
canabus
Re: Sea Raven
« Reply #26 on: February 01, 2021, 11:56:07 am »
Hi Zooma
Just a standard roof light hatch.
Changed my colour ideas !!!
Light blue cabin with white inside the outer cabin and mid blue sides.
White for the hull bottom.
canabus
Andy M
Re: Sea Raven
« Reply #27 on: February 01, 2021, 12:59:11 pm »
Really sorry, got carried away there.
Andy M
Re: Sea Raven
« Reply #28 on: February 01, 2021, 01:04:10 pm »
You can get a moderator to remove the Vivacity stuff and keep the thread on track with the Raven build.
zooma
Re: Sea Raven
« Reply #29 on: February 01, 2021, 01:40:13 pm »
I thought it was quite interesting really Andy - could you start a Vivacity thread instead and get your content moved into it?
There has been some chat about the Vivacity on the other forums recently so it could be of some interest to the Mayhem as well!
Bob.
Andy M
Re: Sea Raven
« Reply #30 on: February 01, 2021, 02:09:37 pm »
I am considering a half-ish scale version, I need to hunt out the plans if I still have them. Will start another thread when the time comes.
madwelshman
  • Learning all the time.
  • Fairey Marine Fanatic
Re: Sea Raven
« Reply #31 on: February 01, 2021, 11:03:37 pm »
Andy,
Just sent you a message.
Will
49" Precedent Perkasa
46" Aerokits Sea Queen
42" Veron Fairey Huntsman 28 x2
34" Lesro Sportsman mk1
34" Precedent Fairey Huntsman 31 x3
34" Aerokits Sea Commander x2
29" Aerokits Sea Rover
20" Aerokits Fast Patrol Boat
16" Aerokits Sea Urchin
roycv
Re: Sea Raven
« Reply #32 on: February 02, 2021, 10:48:09 am »
Hi I have just been reading this thread and the deck finishing.  I usually scrape the deck with a Stanley knife blade held in some electicians tape.  Then a thinned varnish put on with a finger pad of lint free cotton material.  It dries quickly and then have another scrape until satisfied.  Varnishing the deck with a finger pad prevents brush marks and several thin coats look better anyway,
Bit late now but an interesting build.
Roy
zooma
Re: Sea Raven
« Reply #33 on: February 02, 2021, 10:55:18 am »
Hi Zooma
canabus
That sounds good Harry - the colours are almost Fairey-ish  8)
....soon be time to give that Spearfish a run for its money!
Bob.
canabus
Re: Sea Raven
« Reply #34 on: February 06, 2021, 12:01:51 pm »
Hi All
Well I cracked on to adding a bit of colour to the boat, but sourcing the rudder bits has hit a dead end .
I have made the rudder tube, but the stopping point is the flat brass for the rudder !!!
Canabus
zooma
Re: Sea Raven
« Reply #35 on: February 06, 2021, 12:13:55 pm »
That looks really nice Harry, can you use a commercial rudder and throw away the plastic mounting tube ?
As long as your tube is M5 it will fit and if you buy the XL size you will have enough blade to re-shape if you want to change it?
canabus
Re: Sea Raven
« Reply #36 on: February 07, 2021, 08:32:28 am »
Hi Bob
Rudder is in hand, my go to mate is going to make me one from stainless steel.
Harry
canabus
Re: Sea Raven
« Reply #37 on: February 15, 2021, 10:51:47 am »
Hi All
Made and installed the cabin doors and door hatch.
Canabus
zooma
Re: Sea Raven
« Reply #38 on: February 15, 2021, 11:10:40 am »
That is looking very clean and tidy Harry - nice work  :-))
Bob.
Re: Sea Raven
« Reply #39 on: February 15, 2021, 11:54:59 am »
Don't know how I missed this one but, having read through it, I'm astounded by the quality of it all  :o , the planking in particular is simply beautiful.
Watching from here on in.  :-)
canabus
Re: Sea Raven
« Reply #40 on: February 19, 2021, 03:57:26 am »
Hi All
Well after making a nice boat stand for the Smit Nederland.
The stand for the boat has been greatly modified !!!
I was not happy it !!!!
So after a lot of chop chop and a short hair cut at the back.
It turned out OK!!!
First coat of vanish on and the second tonight after it cools down !!!
High density foam with stick on back added after the second coat dries( the same stuff used on the base on my sander).
30C is a bit warm in the shed !!!
Harry
canabus
Re: Sea Raven
« Reply #41 on: February 21, 2021, 11:03:16 am »
Hi All
That dam boat stand is finally fix !!!
The boat sits in the stand right !!!
My custom rudder has arrived !!!
Forward march !!!!
Harry
Andy M
Re: Sea Raven
« Reply #42 on: March 01, 2021, 11:35:47 pm »
I was wondering what the dark area was on the bottom of the rudder, then realised it is a reflection of your fingers because it is so polished.
