Thanks for the various replies.
I have established the scale diameter from the Damen drawings - that is the origin of the image in the first post. It would be 55mm although I'm expecting to use 50mm to give an easier clearance inside the korts, and that size has more choice available.
As for the motor power, hmm. I was recommended elsewhere: "540 motor should be plenty, don’t need anything fancy either. 35-55turn if not geared. " This was for 2" props on a similar tug. Using the cube root scale factor for power, the full sized tug has a total of 1,790,000 watts power. That divided by 32 cubed = 54W which at 7.2v is about 4A per motor. I can't find it now but I thought I read that was about the current draw of this or a similar motor at maximum efficiency. Perhaps someone else has relevant data.
The motors are already in transit. My question refers to the performance difference, relevant to this application, of 3 vs 4 bladed props. I'm more familiar with RC scale helicopters. There, more blades = more lift for a given rpm.
