Author Topic: Model Slipway Gry Meritha 1/40  (Read 3562 times)
robbie the boatman
« on: January 17, 2021, 04:11:37 pm »
hello,
My fellow marine modelers my name is Rob from Penzance, Cornwall. Finally getting back into building scale working models again after many years break partly due to my job. Background, I brought a second hand model slipway kit of the Gry Meritha which operates from my home town, a model I have wanted for a long time. Kit i brought has about 90% of the parts, some missing white metal parts and printed parts. The biggest problem I am have at this time is there is no general deck arrangements drawings to show me where all the parts are located. I have searched the internet far and wide, but have had no such luck to date. In a a last ditch effort I thought i would post here in a bid someone could be so kind to help me. Any help would be much appreciated so i can start a build thread and get this project underway.
your aye
rob
robbie the boatman
Re: Model Slipway Gry Meritha 1/40
« Reply #1 on: January 17, 2021, 04:18:52 pm »
Added a few of where she is at mo...
robbie the boatman
« Reply #2 on: January 31, 2021, 05:59:00 pm »
My Gry Meritha refit- construction has finally lifted off the ground at last!!!. This could not have been possible or somewhat labored if not for the help of "John Lambert" who has allowed me to borrow his plans to build my model, this guy is a legend. I can not thank him enough for his help and advice so far allowing me to make a start on my next project.
Its worth mentioning that this kit was brought second hand and had clearly been in storage for along time and had suffered considerable damage to the various areas, with this in mind I decided my best option was stripping model right back to bare basics and starting all over. My major decision in this factor was the running gear. First phase of my refit was dismantle of decks and beams carefully as will later use as templates for replacement parts.Once decks removed; this allowed me to remove the shafts and A-frames etc, with a little help from my heat gun. The epoxy was very soft and made this job very easy. Shafts will be upgraded along with rudders & props.
I had to remove the Gry Meritha letters on side of the hull. these were glued on very well and broke when i removed them. I had replacements laser cut.
After all metal and plastic fittings had been removed, my next phase of the build was removing all the paint on the outside of the GRP hull. To do this I used a paint stripper that can be used on GRP. This worked extremely well but took a couple of days to complete i.e. red one day and blue the next.
Once washed and cleaned it came out okay. I stayed was clear of using wire wool as not to scratch hull. I used a stiff stable brush and cellulose thinners for any stubborn areas that the stripper had trouble lifting, mainly in corners.
During removal of the shafts I noticed there was a break to the left on the starboard shaft entry point. To make life easier for me, I decided to glass fibre the inside and fill from the outside. This will allow me to install the new shafts etc without hassle later stages of the build.
After this I could finally make a build stand out of MDF, cheap and not bothered if paint/glue deposits during construction. I will make a solid wood stand near the completion of the build. Templates used are provided (DRG:14)
In my next update, I will begin installing the running gear including bow thruster and fabricate two new aluminium rudders. Then i can turn my attention to construction of the deck beams and decks.
All the best for now.
robbie
RST
« Reply #3 on: January 31, 2021, 06:13:07 pm »
Gosh that's quite a re-build!  It looked OK on previous photo but perhaps the camera lied.
I'm always surprised when running gear is easily removed.  Perhaps I shouldn't be, says allot.
I like this boat.  I've looked it up many times and it looked in a sorry state with more recent owners.  I always fancied this kit, never had the money before and no chance now I do.
Good luck with the re-build though looks you won't need it.
robbie the boatman
« Reply #4 on: January 31, 2021, 06:41:02 pm »
Thank you for your reply and interest. These kits are like gold dust now as you know as Model Slipway are no more unfortunately, so when this kit came up I made the decision to buy as i always fancied a model of the Gry Meritha; all be it this model will require some TLC to bring it all together.
More updates to follow.
awvs
« Reply #5 on: January 31, 2021, 07:04:27 pm »
Hi Rob,
Nice to see somebody else building a Gry Maritha. I did build mine about 10 years ago and posted pictures of her right here at Mayhem. I double checked my old post and the pictures are gone. If you are interested I can email them to you or repost them here.
Wilhelm
RST
Re: Model Slipway Gry Maritha 1/40
« Reply #6 on: January 31, 2021, 07:43:43 pm »
I'm just staggered you took it back so much, and so clean you got it back to!
robbie the boatman
« Reply #7 on: January 31, 2021, 07:53:01 pm »
Hi Wilhelm
Thank you for you reply. Any help would be gratefully appreciated and would love to see your model please feel free to share. Any tips, pointers or advice most welcome.
Please keep any eye out for future updates as I progress with construction.
robbie the boatman
« Reply #8 on: January 31, 2021, 08:14:17 pm »
RST
Thank you 🙏 sometimes you have to make a decision and go for it. I am hoping I can make a model that will bring years of happy sailing about on the lake at weekends.
awvs
« Reply #9 on: January 31, 2021, 08:24:27 pm »
Hi Rob,
here are some pictures of my Gry Maritha. I hope this will help with some of the details. Both radar screens rotate and all the hatches open and close. The crane lifts and rotates. I also included a sound module by Action Electronics.
You are doing a fine job. :-))
Good luck
Wilhelm
robbie the boatman
« Reply #10 on: January 31, 2021, 08:40:33 pm »
Wilhelm,
Holy crab sticks!!! This build is absolutely stunning, gonna have my work cut out to get anywhere near your standards. Thank you for sharing these will be very useful over the coming weeks. Do you still own here?
If I get into any difficulties I know where to come. :-)) :-)) :-)) :-)) :-)) :-))
awvs
« Reply #11 on: January 31, 2021, 08:50:47 pm »
Thanks Rob, yes I still own her and will never sell it.
I am sure your Gry Maritha will turn out great. :-)) :-)) :-))  My kit was also second hand and this is a picture of the hull when I got it. I also added a layer of fiberglass inside the hull to close all the holes.
Wilhelm
robbie the boatman
« Reply #12 on: January 31, 2021, 09:17:55 pm »
Wilhelm
Looks like we both have faced similar starts with our Gry Builds.  :-) :-)) :-) :-))
robbie the boatman
« Reply #13 on: February 05, 2021, 06:10:09 pm »
Been busy this week sourcing all the running gear to install. I think I have covered most of it but batteries.
Propellers:-
MFA Motors:- 6:1 ratio
Bow Thruster & ECS:-
Caldercraft M4 12 inch shfats:-
Motor ECSs, Power Board and Alloy Rudders I made:-
I think i am ready to begin installing the running gear this weekend....more progress to follow.
Page created in 0.341 seconds with 18 queries.
