Author Topic: Esc what is a good reliable one  (Read 2851 times)
tassie48
  • bikes birds and burnups
« on: January 18, 2021, 01:39:04 am »
I use to use electronize speed controllers, so looking for a good brand reliable one using the t12 motor from mobile marine models 12 volt system what do you guys use thats good tassie48
canabus
Re: Esc what is a good reliable one
« Reply #1 on: January 18, 2021, 09:49:56 am »
Hi Tassie48
I use Hobbywing Quicrun 60Amp brush motor ESC which run on 2 and 3S lipo batteries.
Link setup for NMIH and Lipo batteries , also for the forward/reverse setup.
This is the only one I have found that will go straight from forward in to reverse !!!!
The connectors I change to gold bullets on the motor and XT60 for the battery side.
Canabus
« Reply #2 on: January 18, 2021, 10:03:39 am »
While I would hope that an ESC intended for 3S "should" be OK on a 12 volt (presumably SLA) setup, I would go for an Mtronics marine viper of the same rating as the Elecronize, maybe the next higher current band to give a bit more safety factor.  Or one of the Action offerings.
Akira
« Reply #3 on: January 18, 2021, 01:59:30 pm »
I have used these with great success. Wonderful low end control. Self programmng
https://www.modellbau-regler.de/shop/product_info.php?products_id=52&MODsid=b6883d885ceed418628e9506d67bbea1
Stan
« Reply #4 on: January 18, 2021, 02:41:37 pm »
Sadly the electronize E S C are no longer available with this in mind  I would have to agree with Malcom on his recommendations.
Stan.
Barney Magrew
« Reply #5 on: January 19, 2021, 11:24:48 am »
The Quikrun esc has always given good results.
« Reply #6 on: January 19, 2021, 11:56:34 am »
Mtroniks are nice and simple:
  https://www.mtroniks.net/
Stan
« Reply #7 on: January 19, 2021, 12:23:31 pm »
Hi Tassie reference speed controllers each one will have its good points and bad points. I take a very cautious approach to some specs given. For me I use Action along with MTronicks. The Hobby wing controller works fine but there are so many to chose from I am sure members will be able to supply more info to other E S C.
Stan. At the moment {:-{ {:-{ {:-{ {:-{ {:-{ {:-{ {:-{ {:-{  hopefully  :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-))
phil_parker
    • Phil's Workbench
« Reply #8 on: January 19, 2021, 06:13:48 pm »
Another vote for MTroniks. Used loads. Never had a problem. They even survive sinking!
Page created in 0.033 seconds with 21 queries.
