Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13   Go Down
Author Topic: RV Nord Icelandia  (Read 62308 times)
Ghost in the shell
Re: MV Nord Icelandia
« Reply #100 on: November 25, 2007, 03:32:45 pm »
just need to get the radar sorted out now, all I need for that is a piece of material 1 inch long, and a cocktail stick, along with a piece of tube.  dont see the point of buying a full length of styrene for that!
Go Nuclear!  you'll love it
« Reply #101 on: November 25, 2007, 06:31:52 pm »
Looking good Mark oh you are a skinflint you could have used the styrene for something else!!!!!!!!!!
Stavros     O0
Ghost in the shell
« Reply #102 on: November 25, 2007, 07:23:42 pm »
thanks Stavros :)
found a use for the old rams,
to make the rotating bar I have some wood cut to length and will mount it to a bar, then push the entire lot into the servo head
cos918
« Reply #103 on: November 25, 2007, 11:22:55 pm »
hi ghost been reading this theard with great interest, the boat is comming on great. I remember you were asking for details on the A frame . I found this pitcher on the net hope it is of some use to you. john
Ghost in the shell
« Reply #104 on: November 26, 2007, 02:59:25 pm »
thanks Cos, however at the moment the A-frame is locked. :(
bigfella
« Reply #105 on: November 26, 2007, 10:43:34 pm »
Hi Mark
It really looks good. Such a quick build too. O0 O0 O0
Regards David
Ghost in the shell
« Reply #106 on: November 27, 2007, 02:49:53 pm »
Hi Mark
Regards David
with the superstructure being nothing more complicated than an ABS box, that is why i was able to progress so well, having said that, IF the hull was to be built as well, I'd probably be working on it still!! lol.
Thanks Dave, sails well(ish) too :)
Ghost in the shell
« Reply #107 on: December 02, 2007, 06:07:38 pm »
The top of the superstructure now has a roof at the right height, added to that, her radar is now mounted to its mast and is powered up.
« Reply #108 on: December 02, 2007, 07:13:19 pm »
So where're the photos then ? :-\
Ghost in the shell
« Reply #109 on: December 02, 2007, 08:32:28 pm »
i'll post them later on
Ghost in the shell
« Reply #110 on: December 14, 2007, 10:46:19 pm »
latest pics of Nord Icelandia
Ghost in the shell
« Reply #111 on: December 14, 2007, 11:12:00 pm »
this is Mr Lobster, an RTR sub, 3" long, based on the jastec shinkai 6500, it is pretty close to the required scale.  the real one can dive to 6500m! thats a tad on the deep side, and one is on the way to me from cornwall.  add a cradle and it will be sitting on the back of the ship.  then its a case of try and get the frame working if it can be done at all
« Reply #112 on: December 15, 2007, 12:26:55 am »
Ghost the impossible YOU can do at ONCE it is the MIRACLES that take the LONGEST ;)
Ghost in the shell
« Reply #113 on: December 15, 2007, 01:07:13 am »
Halleluja !
Ghost in the shell
« Reply #114 on: December 15, 2007, 09:53:03 pm »
well the sub arrived today :) now I have to find a way of getting a hook installed on the sub without the risk of making her instantly plummet to the lake bed.  a sub for llanberis she isnt, 20" max diving depth, (I presume because of the radio inside her).
she dives by means of a thrust motor which is either on or off, and manouvres by means of a propeller at the back and a rotary agitator at the bow.  a plug in her side means she can be charged, with charging being done off the tranmitter, after poweing down to the pool bottom, she can then cruise around as she surfaces.  If i can get the A-frame working the ship could then retrieve the sub.  That is going to requre some studying.
Ghost in the shell
« Reply #115 on: December 15, 2007, 11:31:06 pm »
this is Mr Lobster in the tank, photo taken for a mini review for www.rcgroups.com.
The sub itself has an internal battery, not big either, enough for 2 mins of running.  movement is by 3 motors, a vertical thruster to send her down, and up under power, though she will surface on her own if the motor stops.  A bow mounted thruster, and a regular albeit small propeller at the stern to propel her forwards.
She is a near-scale model of the Jamstec Shinkai 6500, the only thing that isn't too accurate is the length, she is about 10mm too short, however im not going to moan about that.  Sitting on the deck of Nord Icelandia, she looks lost, though not a surprise, those 2 man mini subs are not big
bigfella
« Reply #116 on: December 16, 2007, 12:10:35 am »
Hi Mark
Wow she is really looking great O0 O0. When you get the A frame sorted to launch the sub that will really be something to see in action. To bad you cant upgrade the battery inside the sub for a longer dive time. How are you going about the A frame????
Regards David
Ghost in the shell
« Reply #117 on: December 16, 2007, 12:15:07 am »
the A frame is something I have yet to think about, I'll probably look at that over the comming year, space in there is tight so a winch and spring system may be used
Ghost in the shell
« Reply #118 on: December 16, 2007, 12:20:47 am »
when i do get the frame sorted out, the ship will have to use FLAT CALM water to launch and retrive the sub, after christmas im going to order more styrene i think to work on the A-frame again
bigfella
« Reply #119 on: December 16, 2007, 12:33:49 am »
I was thinking how hard it would be to launch it in any type of rough water.
Ghost in the shell
« Reply #120 on: December 16, 2007, 12:40:16 am »
launching i doubt would be hard, getting her back wont be easy
bigfella
« Reply #121 on: December 16, 2007, 12:45:09 am »
Yeah thats true, wold have to have some sort of locater to ensure that the hook goes on properly. Or you would have to have a recovery boat with a scoop on standby.
Ghost in the shell
« Reply #122 on: December 16, 2007, 12:47:41 am »
I was thinking of a V shaped bar on the sub, with a hook hanging off the A-frame, so as the sub comes in, the hool will latch onto the bar and then haul her up.
I have to be very careful as well, she only weighs 31grams
bigfella
« Reply #123 on: December 16, 2007, 12:52:09 am »
But don't forget that the sub would probably be out of juice and you are relying on the movement of the mother ship or the a frame to get it into position. You would have to be very precise.
Ghost in the shell
« Reply #124 on: December 16, 2007, 12:54:28 am »
with the model having no stern thruster, picking the sub up will be fun, not impossible though, a-frame wont have any latteral movement either, just a swing arc.
Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13   Go Up
Page created in 0.097 seconds with 21 queries.
