Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13   Go Down
Author Topic: RV Nord Icelandia  (Read 90947 times)
Ghost in the shell
Re: MV Nord Icelandia
« Reply #25 on: October 19, 2007, 11:36:42 pm »
...Also the propshaft hole has been cut out.
to get from Blackpool show, plywood, ABS sheet, Motor+mount, Proboat esc lead and a servo for the skip-lift
Go Nuclear!  you'll love it
Ghost in the shell
« Reply #26 on: October 21, 2007, 09:12:41 pm »
so far :)
Ghost in the shell
« Reply #27 on: October 21, 2007, 09:25:51 pm »
At the stern there is a bulkhead, this along with eventual glazing in of the freeing ports shal reduce the onset of red pelican syndrome yes tug kenny!!!! :P rather than having one bulkhead I have made it out of 3 parts to make it look like it could be raised or lowered.
« Reply #28 on: October 21, 2007, 09:27:45 pm »
                                                O0
The long Build
« Reply #29 on: October 21, 2007, 09:30:24 pm »
Hi Ghost
Nice to put a face to a name.
The skip  lift , is that going to be operational ?
Larry
Ghost in the shell
« Reply #30 on: October 21, 2007, 09:35:22 pm »
Thanks Kenny.
Larry, it was planned to be however there is a major bulkhead between the rudder stem and the lift, so thats kinda scuppered that plan, so the A-frame is a dummy at the moment however the hinges are still operable and so all that would be needed to do is the hydraulic rams be replaced should a suitable mechanism be found
The long Build
« Reply #31 on: October 21, 2007, 09:41:52 pm »
I'm sure you will sort it , when ever there is a hammer, chisel, drill and knife and some glue there is always a way.. Can't believe you actually did some building there at Blackpool , I get nervous when my wife is watching let alone a few thousand people..
Ghost in the shell
« Reply #32 on: October 21, 2007, 09:43:18 pm »
I felt like I was on BIG BROTHER!
Ghost in the shell
« Reply #33 on: October 22, 2007, 11:21:39 am »
At some point I plan to get the A-frame re-moddelled on the aft fan tail,
After some thaught, I think a sail winch should do it, running a constant loop ala yacht should do it.  anchored to the bottom of the winch and then anchored to the hydraulic ram pivot.  thats's for another date.
rp6705
« Reply #34 on: October 23, 2007, 08:39:26 am »
Looking good now Ghost  O0
Ghost in the shell
« Reply #35 on: October 23, 2007, 10:43:52 am »
Russ on sunday I hope to get her wired up, then ballasted, so hopefully by the end of october she should be on the water so pics will be posted when she sails
Ghost in the shell
« Reply #36 on: October 27, 2007, 05:42:25 pm »
well she sails :)
a motor change was made after initial bath testing - she wouldn't go very fast at all, taking 4 seconds to travel the bath, this motor was changed by a 380 MFA motor.
on the water she rolls slightly and may need a keel skeg to get her stability ind running straight.  not a big issue though
The long Build
« Reply #37 on: October 27, 2007, 06:00:20 pm »
Thats A big bath  O0 ;D
Ghost in the shell
« Reply #38 on: October 27, 2007, 06:33:01 pm »
only a standard bath, just so bloody slow!
The long Build
« Reply #39 on: October 27, 2007, 06:36:35 pm »
Sorry I was referring to the pond in the pictures..which are on the same post as the bath..
Still your getting further Than I am at the moment..
Ghost in the shell
« Reply #40 on: October 27, 2007, 06:45:40 pm »
no worries
she seems to back up straight as well.  next thing structural is a pair of vertical fins on the hull at the aft end to help keep her running straight
6705russell
« Reply #41 on: October 27, 2007, 08:21:24 pm »
Looks well Ghost, my tug was a bit unstable so i have added a couple of stabilisers, iwill test it tomorrow if its fine.
Russ
Ghost in the shell
« Reply #42 on: October 27, 2007, 09:28:41 pm »
your tug shuldnt be THAT unstable, Kim and his father used two dickies in a tug towing event and they had no problems, try fettling your ballast.
mine now needs a sh*t load of paint added!
Ghost in the shell
« Reply #43 on: October 27, 2007, 11:10:59 pm »
old pens DO have a use when hacked up with a saw.  the funnel cans and the crane support are made from the outer casing of an old biro
bigford
« Reply #44 on: October 28, 2007, 01:16:26 am »
that is one good looking ship you got there ghost
Ghost in the shell
« Reply #45 on: October 28, 2007, 03:39:44 pm »
bridge wings / boat deck added
« Reply #46 on: October 28, 2007, 03:47:14 pm »
Still haven't got a new camera then ghosty ? :-\
Ghost in the shell
« Reply #47 on: October 28, 2007, 03:56:05 pm »
no.
hving said that, I dont think its the lens thats the problem, more the chip that records the image
Ghost in the shell
« Reply #48 on: October 28, 2007, 03:57:04 pm »
by the way, I need help. canister type life boats, are they mounted horizontally on the deck OR on a vertical surface?
« Reply #49 on: October 28, 2007, 04:36:17 pm »
Do you mean this type  :-\
Pages: 1 [2] 3 4 5 6 7 8 9 10 11 12 13   Go Up
