Pages: [1] 2 3 4 5 6 7 8 9 10 11 12 13   Go Down
Author Topic: RV Nord Icelandia  (Read 62309 times)
Ghost in the shell
RV Nord Icelandia
« on: October 14, 2007, 10:05:55 pm »
well purchased off stavros £**
Any idea what plan its off?
Go Nuclear!  you'll love it
rp6705
Re: MV Nord Icelandia
« Reply #1 on: October 15, 2007, 07:37:06 am »
Looks very similar to Slipways Aziz?
Voyager
« Reply #2 on: October 15, 2007, 11:31:26 am »
I thought the same ???
Ghost in the shell
« Reply #3 on: October 15, 2007, 04:29:54 pm »
well the rudder is in and the latteral bridge supports are in place now.
Ghost in the shell
« Reply #4 on: October 15, 2007, 05:48:18 pm »
cabin deck done in two sections, currently only aft section is glued down,
« Reply #5 on: October 15, 2007, 07:33:32 pm »
Ghost sorry to disappoint you but it was apparently a model based on the Seaforth |Conquerer,that what I was told keep up the good work.
Ghost in the shell
« Reply #6 on: October 15, 2007, 07:59:42 pm »
thanks Stavros, Bluebird said it looked similar, however when do i ever keep a kit's name???? :P its glazed now as well,
Ghost in the shell
« Reply #7 on: October 15, 2007, 11:28:45 pm »
as for livery, not decided yet, though her bridge pannels will be orange.  Blackpool show, motor, new stainless shaft, 35mm prop, with a UJ.  esc - Proboat Tornado 50 servos will be by Futaba.
rp6705
« Reply #8 on: October 15, 2007, 11:42:12 pm »
Hey there Ghost,could have some tug competitions, my Dickie workboat is completely stripped down and i have started to respray, will post some pics tomorrow.
Russ   O0
Ghost in the shell
« Reply #9 on: October 16, 2007, 03:40:25 pm »
towin will be with Southie, Nord Icelandia is to have a skip-lift on her stern
Ghost in the shell
« Reply #10 on: October 17, 2007, 03:33:09 pm »
speaking about spray jobs, I have to paint the hull on the ship along with the main deck.
The hull Im gonna have white and red, the deck is going to be Matt green.  Adding lights should be easy as well, the hull is just a BIG void. having a front bulkhead also means that seperation of gear is also possible, so add a battery up the front and a battery back aft, along with some lead to trim.  Im planning on using 6v 4.5ah battries on her
rp6705
« Reply #11 on: October 17, 2007, 04:05:15 pm »
Are you having the A frame at the back operational?
Russ
Ghost in the shell
« Reply #12 on: October 17, 2007, 04:46:10 pm »
it HAS been sugested :) and at the show Im going to look into the feasibility of it.
I think I will need a LONG servo arm, probably off a yacht, and a sail winch.  then on the skip-lift at the stern, a small servo linkage.  should be fun to do
Ghost in the shell
« Reply #13 on: October 17, 2007, 04:51:00 pm »
by playing around with EPA I think I may be able to adjust the travel of the arm to a fully IN and fully OUT position, rx for that will be the one in Espirit.  the sail winch will probably be assigned to ch6, thats IF i animate it
Ghost in the shell
« Reply #14 on: October 18, 2007, 03:52:49 pm »
well the hull's almost painted now
Ghost in the shell
« Reply #15 on: October 18, 2007, 04:35:13 pm »
its red BUT i'm not happy, spent a couple of evenings sanding and, well I daren't sand down any more for fear of taking off the glass. it may need some fressh gel cote or a skim of filler and a second layer of paint, but here it is as she stands now
« Reply #16 on: October 18, 2007, 04:36:39 pm »
Move the bridge back, cut the front off - SPRINGER!  ;D
HS93 (RIP)
  • I cannot spell , tough
« Reply #17 on: October 18, 2007, 04:41:54 pm »
Just let him run it around Dean pool a few times and he will knock them of. :D
Peter
Ghost in the shell
« Reply #18 on: October 18, 2007, 04:43:38 pm »
only YOU could come out with that one! :P
« Reply #19 on: October 18, 2007, 05:52:45 pm »
Oh dear me why do I waste my breath didn't I TELL YOU IT NEEDED FILLER ON THE HULL DOH
stavros
Ghost in the shell
« Reply #20 on: October 18, 2007, 06:10:23 pm »
well with the sanding down!
Ghost in the shell
« Reply #21 on: October 19, 2007, 04:45:10 pm »
well its repainted now, much better finish :)
« Reply #22 on: October 19, 2007, 07:00:38 pm »
Ghost in the shell
« Reply #23 on: October 19, 2007, 09:16:56 pm »
its along those lines BUT I plan to build a skip lift for her at blackpool show if i can get the bits thre
Ghost in the shell
« Reply #24 on: October 19, 2007, 11:34:10 pm »
well this is her now after her repaint. not perfect but A LOT  better
Pages: [1] 2 3 4 5 6 7 8 9 10 11 12 13   Go Up
Page created in 0.088 seconds with 22 queries.
