Author Topic: Miranda/Choupette - Engine suitability ?  (Read 524 times)
CliveJ
« on: February 22, 2021, 09:38:43 am »
Advice & help please
I am looking to build a Choupette steam launch. I have plans for the Miranda steam engine (+ plans for the Miranda steam launch).
On reviewing all plans it appears the Miranda engine may be too powerful for the Coupette (The Miranda plans detail a 2 1/2" propeller, the Choupette 40mm)
The reason I am choosing to build the Choupette in this instance is that it is a far faster build time.
Can I simply reduce the bore size from 1/2" to 3/8" on the Miranda engine to reduce the power and thereby reduce the size of the boiler ? if so at 3/8" bore I am assuming it will be powerful enough ?
Or is there a better option in an alternative engine ? I'm interested in building the engine from bar stock & not purchasing a kit/castings
Thanks in advance  :-))
Clive
Re: Miranda/Choupette - Engine suitability ?
« Reply #1 on: February 22, 2021, 11:07:20 am »
You could reduce the bore, but the other option is to build as is and just reduce the steam pressure that you run the engine at, that way should you need more power at any time it will be there
KBIO
« Reply #2 on: February 22, 2021, 04:49:57 pm »
Good evening.
I've been looking and asking around but no chance. {:-{
[/size]The only drawing that I found is below. Good enough to do the work when you have decided what length you want.
[/size]Also , is a chart of the propeller size according to the engine capacity. The left column shows the weight range in kg.
[/size]The Choupette should weight  a small 5 kg for a meter long.
[/size](Sorry, it's in French but the numbers are universal)Hope it helps !Regards.
CliveJ
« Reply #3 on: February 22, 2021, 05:30:08 pm »
Thanks Steamboat Phil, I was looking to reduce (Miranda) boiler size - if I keep the standard engine will I need to keep the 'larger' boiler ?
I guess I was looking to reduce the size/weight of the whole steam plant but still retain sufficient power & a reasonable rum time
Thanks again Clive
CliveJ
« Reply #4 on: February 22, 2021, 05:31:53 pm »
Good evening.
Hi KBIO, apologies for the confusion - I have the Choupette plan - I was just seeking advice in respect of the power plant
Thanks Clive
frazer heslop
« Reply #5 on: February 22, 2021, 09:36:32 pm »
The boiler for Miranda even when gas fired  to be kind is a bit lacking
cheers
KBIO
« Reply #6 on: February 24, 2021, 10:57:52 am »
Hello Clive !
I thought  of you and I found out the answer to your question.
I have 2 files concerning teh Choupette and the steam set to go in.
Unfortunately, I cannot post pdf on the Forum , so if still interested, give your mail on MP and I shall send you the complete doc.
The engine (easy to machine down) is a 3cc.
If you have any question, do not hesitate to ask.
Have a good day! :-)
CliveJ
« Reply #7 on: February 24, 2021, 11:50:47 am »
Hello Clive !
Great :)  thanks for the offer PM sent
Regards Clive
KBIO
« Reply #8 on: February 24, 2021, 12:41:22 pm »
Hello !
Done !Sent by ail!
Sunny day here today and the grass is high enough ! Can't delay anymore ! O0
Best regards.
