Author Topic: Thin Ply in long lengths  (Read 1625 times)
spearfish99
« on: February 22, 2021, 01:41:13 pm »
  I have just obtained some plans to build an A class yacht. It is effectively built from long ply panels edged glued then taped etc. I have seen this used for smaller yachts and it works very well as you end up with a light weight hull with no formers to get in the way of fitting out.
 The biggest issue on the A is to find ply wood to make the panels. Ideally, what I would be looking for would be 1.0mm -1.2mm ply in sheets about 2.4metres long.  I can find 1.5mm at about 60" long at SLEC.  Just wondered if anyone had come across anything else. I have been looking at firms who laser cut plywood to see if there is anyone who offers anything similar , as the designer supplied a set of .DXF files for the panels which is what I believe the cutters use.
 Any leads would be of interest
AlexC
Re: Thin Ply in long lengths
« Reply #1 on: February 22, 2021, 02:00:43 pm »
Hi Spearfish99,
Your best bet would be to go to a good timber supplier.
The following all list 0.8 and 1.5mm birch ply in large sheets... typically 8ft x 4 ft or up to 1525 x 1525mm sizes.
https://www.specialisedpanels.co.uk/birch-
plywood.htmlhttps://www.lathamtimber.co.uk/products/panels/plywood/birch-plywood/thin-finnish-birch?utm_medium=organic&utm_source=bing
http://https://www.chilterntimber.co.uk/product/plywood-aircraft-birch-plywood-grade-1525-x-1525-x-1-5mm/
http://www.dhhtimber.co.uk/birch_plywoods.htm
Some of these may be able to supply bigger sheets.
There are many more listed in the UK on the net.
Hope this helps.
AlexC
Grumpy Dave
« Reply #2 on: March 11, 2021, 09:51:12 pm »
Could you not scarf short planks to make long ones?
spearfish99
« Reply #3 on: March 23, 2021, 06:50:40 pm »
Found an answer to the problem
  [size=78%]PRICES - Aircraft Plywood and Timber[/size]
