https://i.ebayimg.com/images/g/FbkAAOSwVQhgLy4e/s-l64.jpg
Hi, im considering this for my tiny work shop, currently i have a dremel work station pillar drill, but it wonders when i try to drill, so hoping this would be a good bet, whats your opinion
Trucker
Before you go throwing money around it is worth going through all the basics first. The Dremel is a very good quality machine and should do the job well. The big advantage of this arrangement is that the Chuck is mounted directly on the motor rotor shaft so there is relatively less loading on the bearings and no side load. The alternative you are looking at is a similar arrangement so is also a much better set up. The problem with remote mounted motors is side loading on the spindle bearings which invariably leads to wear on particularly the top bearing and consequent misalignement, especially if the belts are not adjusted correctly and constantly changing them to adjust speed doesn’t help. The belts invariably rattle around causing vibration so the natural reaction is to try to over tighten them to compensate. Don’t confuse large heavy castings with robust construction and longevity.
Make sure you eliminate all the basics with the Dremel first, all these can lead to what you describe,
1) Are you using long drills?
2) Are you using cheap drills that are frequently not ground perfectly concentrically?
3) Are you using sharp drills?
Try the following first,
1) If drilling metal centre pop the spot first and even try using a lathe centre drill first.
2) If drilling a soft material are you clearing the swarf frequently and cleaning the tip regularly during a cut? Wood easily clogs the flutes and many plastics build up on the cutting edges, both cause misalignement.
If they do not work and you are sure that the Dremel is at fault then, if it was me, I would simply buy a new Dremel and treat it to a brand new set of high quality drills. If you must change then go for a unit where the Chuck is mounted directly on the end of the motor rotor.
If you are using cheap poor quality drills then you will experience the same challenges with whatever new machine you buy.
