Morning Liam...........firstly, thank you for starting this thread........there will be many questions, hopefully not too many Tourist related
1. the Convenience [32km] passage going astern........I found very interesting....is there a full Bridge Control station [replicating the Fwd Bridge] aloft the stern?,.....for such movements?....do the Fwd & Stern tugs use hard wired cables/hawsers?....does the vessel actually navigate those narrow passages?, or ar the tugs providing forced steering?
2. Inclination trials.....[I have been on a baby 5,000 ton Warship in dock completing these after refit] so yes, a baby compared to your 169,000 GRT
So with the Warship, various steel/concrete mass weights are loaded outboard on deck to simulate the vessels inclination & I understand all this, but how do the Naval Architects and Surveyors conduct such trials on a massive enclosed vessel such as the Symphony?
3. being in the Standard 12 to 4 watch, also denies you the Staff cheap rate for Internet which is a bit of a raw deal
4. so a vessel the size of a big City & many 100's of Staff would need certain Resources........is there any HR type Senoir Staff person on board that you could apply to, to have your internet log in altered to the [lower] Staff rate, or is your Contract so binding to the degree that there is literally no flexibility?
Keep the stories & images coming, they are certainly appreciated
Hello Derek,
1. Everything was controlled from the port side wing, we had both pods and varying levels of thrusters online for the conveyance, the tug boats provided most of the thrust, going astern kept the pods in the centre of the channel - sounds a bit daft but one of our contingencies is to always run aground with the bow if you have no other choice... pods are expensive and easily damaged bow is just a bit of steel plating to be replaced.
I forget the name of the steel things attached but we had a special cradle around the bow for the tug to connect too and the same on the stern which the tugs were fixed too.
2. inclination was done in Eemshaven just after conveyance before we sailed to Bremerhaven same as you probably did it, measured all the weights around the ship, big pendulum suspended in one of the elevator shafts and using our heeling tanks. we can pump almost 1000t of fresh water side to side in these tanks.
3. As we are in the new build stage and also for out of service (coronavirus) the company allowed all crew free wifi... but this will disappear once we resume operations. (the cheap rate is now gone its just fixed at $4 / 60 mins) being in Europe also, I have data roaming.
4. We have a full HR department, think there's about 7 of them on this ship, they help with crew movements, events, and the usual HR related issues...
And Taranis - we tend not to use tugs at all, I see plenty but the idea behind us having such powerful thrusters and pods is to negate the need for tugs, in some ports a large tug is $10,000 a hour.
I will try and remember to take some pics of passing tugs tho.
