Author Topic: Best battery for Quicrun 1060 brushed speed controller  (Read 2692 times)
terry1956
« on: April 12, 2021, 12:34:53 pm »
Hi chaps, what would be the best battery to use with a Quicrum 1060 brushed speed controller. In the little booklet it states you can use 3.38 lipo or 5-8 NiMH battery. I have no idea which is best, I am looking for a long running battery for a submarine. Thanks for your help
Taranis
  • Balne Moor MBC
Re: Best battery for Quicrun 1060 brushed speed controller
« Reply #1 on: April 12, 2021, 12:47:38 pm »
Input: 2-3S LiPo/6-9 Cells NiMH
  • The question is what space do you have? and how much weight can it cope with.
ANDY
terry1956
« Reply #2 on: April 12, 2021, 01:09:46 pm »
I have around 8 inches by 4 by 4. I can trim for weight
Taranis
  • Balne Moor MBC
« Reply #3 on: April 12, 2021, 02:05:41 pm »
That's quite a space  O0  so the next consideration is budget? and the voltage range of the motor.
ANDY
Stan
« Reply #4 on: April 12, 2021, 02:08:48 pm »
Just for future information these E S C will work with gell cell batteries.  I have a Robbe sea wolf submarine powered with 3 cyclone cells using this type OF E S C works fine
Stan. :-)) :-)) :-)) :-)) :-)) :-))
« Reply #5 on: April 12, 2021, 09:26:44 pm »
For the same weight/volume you get longer runs off Lithium.  But if you want to be sure that you can recover from mistreating the battery, NiMh.  In both cases, within what weight can be carried, as big an A/H figure as possible at whatever voltage you decide on.
Lithium gives lots and lots of Watts per kilo and will give enormous current for any given capacity (look up "C" ratings).
NiMH gives rather less stored energy per kilo, and not as much peak current handling.
SLA gives not much wattage per kilo, and a very low C  rating.  SLA "can" deliver enough current to start a car engine, but not for more than a few seconds.  They can not sustain a high current without shortening their life expectancy a lot.  They were tolerated rather than greeted because back in the day they were the only game in town.  Best for low current and where there is a need for ballast.  They also need good ventilation when charging - they have been blamed for the occasional exploding sub.
