Author Topic: The best thinner for resin  (Read 1989 times)
old_gunner
« on: April 25, 2021, 03:41:04 pm »
What would be the best thinner for 2 part resin?
Old Gunners never die, they just drop shorter.
Subculture
    • Dive-in to Model submarines
Re: The best thinner for resin
« Reply #1 on: April 25, 2021, 03:47:46 pm »
What type of resin. Polyester, Epoxy, polyurethane etc.?
john44
« Reply #2 on: April 25, 2021, 03:48:29 pm »
De  natured alcohol.
nemesis
« Reply #3 on: April 25, 2021, 03:53:54 pm »
no more than 10% acetone, nemesis
old_gunner
« Reply #4 on: April 25, 2021, 05:32:28 pm »
Opps, sorry should have stated epoxy resin.
Taranis
  • Balne Moor MBC
« Reply #5 on: April 25, 2021, 05:50:19 pm »
Personally I use Isopropanol
ANDY
old_gunner
« Reply #6 on: April 25, 2021, 06:17:35 pm »
Andy
Thank you for your reply, may I ask what mixture % do you use.
Bill
tonyH
« Reply #7 on: April 25, 2021, 06:32:52 pm »
Bit like bucket chemistry but normally about 5%. I e. don't flood it! :-))
Taranis
  • Balne Moor MBC
« Reply #8 on: April 25, 2021, 07:10:25 pm »
Andy
Bill
It depends what I'm going to use it for but I generally use finishing resin mixed with up to a 30% for a first coat on softwoods and balsa. Ideally I treat both sides of the wood during construction while still accessible.
ANDY
old_gunner
« Reply #9 on: April 25, 2021, 10:24:02 pm »
Thank you, Tony H and Taranis I shall try it in the morning.
Taranis
  • Balne Moor MBC
« Reply #10 on: April 25, 2021, 10:29:16 pm »
Most vital is that both resin parts are exactly equal. I mix the resin then add isopropanol, while mixing it in it will first go cloudy, keep stiring until it is clear again and some more.
ANDY
Subculture
« Reply #11 on: April 26, 2021, 09:40:27 am »
Heat also works in thinning epoxy and doesn't compromise the strength like adding thinning agents.
tonyH
« Reply #12 on: April 26, 2021, 10:05:15 am »
Just to elaborate of the last post, the thinners will only evaporate while the resin is in a gel state. Once it's solid it's fixed and can compromise the strength to a small extent. So any effect will vary depending on how much you use, the environment temperature and also the speed/slowness of the resin cure.This is from EasyComposites a few minutes ago.
Taranis
  • Balne Moor MBC
« Reply #13 on: April 26, 2021, 10:22:43 am »
As I said it depends on what you are using it for.
The situation I described is for maximum absorption as a first coat and finishing resin has a long setting time giving plenty of time for evaporation  :-))
ANDY
Big Ada
« Reply #14 on: April 26, 2021, 04:36:22 pm »
I repaired a cracked hull by pouring the mixed resin inside then warming with a Heat gun and swishing it around, it does not need a lot of heat.
« Reply #15 on: April 26, 2021, 07:43:21 pm »
I sort of do the reverse, heating /warming resin, mixing (while still warm) then applying, long cure time though  :-)
Page created in 0.09 seconds with 22 queries.
