Author Topic: 36 inch Lancet  (Read 2251 times)
sturrock
36 inch Lancet
« on: May 05, 2021, 02:10:16 pm »
I have a model yacht of a 36inch restricted Lancet that my father built in the mid fifties.Unfotunately the wooden mast is twisted and broken. I wish to replace this but have no idea were I could get one or will it have to be made? Thanks for any help.
garethjones35
Re: 36 inch Lancet
« Reply #1 on: May 07, 2021, 03:44:31 pm »
It should be possible to make a replacement wooden mast using a length of pine dowel of the same diameter as the existing mast.  It is not so easy to find good materials these days but as long as it is straight, straight grained and free from knots it should be OK as a starting point.  If you buy from a well known DIY supplier just be careful that it is a single piece of timber, not one that had been joined by a scarfed joint along its length.  Its possible to taper the top half of the mast using a small plane and finish by wrapping a piece of abrasive paper around it to sand it smooth.  Roll it along a flat surface every so often to check you are planing it down symmetrically.
Alternatively you could use a length of aluminium tube, typically 10 mm OD and 1 mm wall thickness would be OK for a 36R.
I restored a Lancet last year as a lock down project and it sails very well.  However I took a short cut and borrowed a rig from another similar aged 36R that we have.  If you need a copy of the original drawing I could let you have one if you pm me your email address.
Mrs Stav
Re: 36 inch Lancet
« Reply #2 on: May 07, 2021, 05:05:39 pm »
use some Kite poles they are carbon fibre
Where's the cake ??? I only joined for the cake !!
Re: 36 inch Lancet
« Reply #3 on: May 07, 2021, 06:29:00 pm »
And kite material also works for sails........ :-))
sturrock
Re: 36 inch Lancet
« Reply #4 on: May 07, 2021, 06:34:36 pm »
Thanks for all you advice.I think I will try to make a wooden mast.The original mast is mahogony which has split so I would like to keep it as close to original as I can.
Re: 36 inch Lancet
« Reply #5 on: May 07, 2021, 07:29:07 pm »
Go for it  :-))
tarmstro
Re: 36 inch Lancet
« Reply #6 on: May 09, 2021, 02:52:15 pm »
You can download the original diagrams from here: http://www.allradiosailboats.com/design/lancet
I hope you don't mind I used your photos for that page....
garethjones35
Re: 36 inch Lancet
« Reply #7 on: May 09, 2021, 03:10:51 pm »
tarmstro
That's fine, I have a few other yachts which are listed on the site without photos and have been meaning to add them for a while.
Gareth
tarmstro
Re: 36 inch Lancet
« Reply #8 on: May 09, 2021, 03:13:15 pm »
tarmstro
Gareth
Thanks - you can send the photos to admin@allradiosailboats.com if that is easier for you....   ;D
Page created in 0.098 seconds with 21 queries.
