Author Topic: Plans Aircraft carrier R09 HMS Ark Royal (09) 63 vrefit  (Read 3555 times)
rayna
 :} Hi
 A friend is searching for a plan for HMS Arc Royal he says after 1963 refit is the model he is interested in.Any help I will pass on to him.Rayna
rayna
Re: Plans Aircraft carrier R09 HMS Ark Royal (09) 63 vrefit
« Reply #1 on: May 13, 2021, 10:15:46 pm »
 :embarrassed: Hi Folks . maybe I should have said that he is looking for a possible source of a plan or alteration details that were done 67 -70 not 63 as previously stated. Should be same as HMS Eagle.Not asking for a "freebie" here.regards againRayna
littoralcombat
« Reply #2 on: May 14, 2021, 10:43:19 am »
Hi Rayna,
May I ask what scale model your friend wishes to build, assuming building is his intention.
Nige
rayna
« Reply #3 on: May 15, 2021, 10:03:26 pm »
1:128 though can convert from any scale I guess.
thanksRayna
Buccaneer
« Reply #4 on: May 16, 2021, 01:50:12 pm »
Be careful when comparing HMS Ark Royal post re-fit with HMS Eagle. Post refit Ark Royal had water cooled jet blast reflectors, strop catchers on both catapults and was fited with two 'double-bedstead' 965 radars. Eagle did not have the strop catchers and was fitted with a 984 'dustbin' radar forward and 965 aft. The wardroom on Eagle also had the largest Bar in the fleet.
Eagle 1969-71.  Ark Royal 1971-72, 73-74, 76-78.
rayna
« Reply #5 on: May 17, 2021, 11:01:15 am »
 :} Thanks John for that info all could be useful if he goes ahead with his project.Rayna
Rob47
« Reply #6 on: May 18, 2021, 09:37:56 pm »
Glad you mentione the most important part of Eagle, the wardroom bar, all the rest does not matter {-) {-) {-) {-) {-) {-)
I will finish this model
