Author Topic: My new speed steam boat project  (Read 4391 times)
rhavrane
  • Steam passionate collector
« on: May 08, 2021, 08:06:49 pm »
Bonjour,
My previous boat having been badly beaten  :(( https://www.youtube.com/watch?v=ysNQ-Prq8II, I embarked on a new steam speed project with improbable elements, a 60 year old Chris Craft hull rescued from the trash, a double burner Babcock boiler that weighs two arms and a very powerful speed machine, luckily.
Before : https://www.youtube.com/watch?v=IRoPl6YDcc0&t=199s
Here is her first test: https://youtu.be/3PRPYb72uAU
I still have some work to do to get her maximum  ok2
Raphaël
rhavrane
Re: My new speed steam boat project
« Reply #1 on: May 10, 2021, 08:08:30 pm »
Bonjour,
I have solved my loss of power issue by using the gas in its liquid phase  :-))
https://youtu.be/1TdwdAKIFKE
I have to find different propellers for the tests I can't wait to start !
Raphaël
« Reply #2 on: May 10, 2021, 08:24:10 pm »
Nice engine, twin cylinder slide valve  I would guess. Looks like it will really go  :-))
rhavrane
« Reply #3 on: May 10, 2021, 08:34:33 pm »
Bonjour Phil,
Slide valve machines do not support high speed, it is just a single acting cylindric valve machine, stalled at 180°, which unfortunately implies dead points and a good management of the idle, the boat can't stop either.
Single acting because piston rods leak a lot also at high pressure, this is true of course for our models machines.
Raphaël
rhavrane
« Reply #4 on: May 13, 2021, 04:32:19 pm »
Bonjour,
For fun, another speed steam machine : https://youtu.be/ubZbn5o6EfI
Raphaël
DBS88
« Reply #5 on: May 13, 2021, 07:17:24 pm »
Raphael that’s an interesting looking boiler, l am looking forward to seeing it running in your speed steam boat, I wish you success with your project
KBIO
« Reply #6 on: May 17, 2021, 10:43:33 am »
Speed boat is a challenging &  interesting project  !
Below is mine ..... aborted ! As usual, I start a lot of things but never finish one.  {:-{ :embarrassed:
Some leaks to work out ! Needs to stay @ 15 b continuously !
Just miss RC to go on ! But big risk of fire !! ;D
Cheers !
https://youtu.be/Z5xGxatN_Yg
DBS88
« Reply #7 on: May 17, 2021, 12:55:00 pm »
Wow what a glorious sound that makes, I hope you revisit the project, it would be such fun to see it running at speed.
rhavrane
« Reply #8 on: May 17, 2021, 01:47:45 pm »
Bonjour Yves,
What a boat, you should have persevered ! I am sure it would be very fast ! The hull is the best I would imagine for a speed boat.
The only point is that your boat would not be allowed to play with us as the Anton trophy rules limit the pressure to 8 bar and I already heard 15 during these teets. I see you chooze the flash steam option, the best for speed to my opinion.
You have finished beautiful boats, you can finis this one and perhaps exceed 30 km/h
Raphaël
KNO3
« Reply #9 on: May 28, 2021, 06:25:49 pm »
Good luck with the speedboat projects. It should be fun to watch them compete soon!
rhavrane
« Reply #10 on: May 28, 2021, 06:43:02 pm »
Bonjour Calin,
It will be interesting especially because my friend Eric is also building one which seems very efficient... on the bench.
The competition will be fierce, especially as other vaporists also prepare their weapons  :-))
I hope I may go to the lake soon to test it
Raphaël
rhavrane
« Reply #11 on: June 14, 2021, 09:07:29 pm »
Bonjour,
My Scott boiler is too heavy, I have bought another one which is twice lighter and I hope as efficient :
https://www.youtube.com/watch?v=VEJDagKRCaI&t=635s
Raphaël
KNO3
« Reply #12 on: June 15, 2021, 06:08:58 pm »
How many water tubes does it have inside?
rhavrane
« Reply #13 on: June 15, 2021, 06:31:15 pm »
Bonjour Calin,
Hope you are fine,
The 10 mm diameter tubes are mounted tightly in a helix over the entire length of the boiler, this is why the burner and the chimney are external, therefore, as it measures 200 mm and there is a small margin in front of the burner, I would say about fifteen without being able to check it firsthand
Raphaël
« Reply #14 on: June 15, 2021, 08:57:35 pm »
Not to confuse but looking at the boiler video it is not a Scott boiler it looks more like a centre flue
rhavrane
« Reply #15 on: June 15, 2021, 09:54:52 pm »
Bonjour Phil,
You are right, there is no confusion, this one is a center flue boiler, but it will repplace this one already installed in the boat and shoewd installed in the first post of this topic : https://www.youtube.com/watch?v=jZHZp-5Y-xk
Raphaël
rhavrane
« Reply #16 on: June 26, 2021, 06:03:58 pm »
Bonjour,
After these tests, I am ready to go on the pond and hope beeing faster than my friends  ok2
https://youtu.be/3j5Zm_vTXPA
https://youtu.be/alrxYPHRd5I
https://youtu.be/BotBc_ZCl2I
Raphaël
« Reply #17 on: June 26, 2021, 11:57:34 pm »
Raphaël
I am not sure you will need the gas heating via boiler warmth, as the Gas Tank is subject to such pulsations of nervous energy from the engine that the gas molecules must certainly be rubbing  %) with each other
Derek :-))
KNO3
« Reply #18 on: June 27, 2021, 08:38:48 am »
Hello Raphael, when and where is the race going to be held?
Your new boat seems to have a strong steam plant, looks like a winner.
rhavrane
« Reply #19 on: June 27, 2021, 11:05:12 am »
Bonjour,
Derek, using gas in its liquid phase is the best way to keep a constant pressure in the tank, I would not trust the vibrations of the engine to prevent the freeze as my boiler needs a lot of gas. A long heated pipe, a large filter prevent me to install a secondary line to start the heat, tis is good news and I thning I will repeat this on my other boats in which the gas tanks freeze.
Calin, The Anton Trophy races are usually run during the Atlantica Steam event or the Vap'IDF event. None of them were organized last year, you know why, and we hope that the next Atlantica Steam event will be organized during the last week-end of Seprember at Cabariot en Charente 17430, close to Rochefort and its royal rope factories.
Raphaël
« Reply #20 on: June 28, 2021, 09:21:13 pm »
Please could you send me details please I would like to take part if I can (you  can PM me in French if you would like).  :-)) :-))
rhavrane
« Reply #21 on: July 24, 2021, 04:15:04 pm »
Raphaël
DBS88
« Reply #22 on: July 24, 2021, 09:07:59 pm »
Raphael the Diano Marina is coming along nicely it looked to be quite quick. The hull looks like a planing hull, if so it would probably give you a significant increase in speed if you can shift the weight as far back as possible, by putting the boiler further back along with the engine . If you can shift the weight back and get the bows up it will go a lot faster for no additional cost just a bit of weight re-distribution
rhavrane
« Reply #23 on: July 25, 2021, 01:32:35 pm »
Bonjour Dave,
You are absolutely right... in theory because the major problem is that this boat was built for a light electric engine, not a > 3 kilos steam plant.
Before these videos, thanks to my bathtub  ok2 I have tried to put the boiler at the aft of the boat but is is 20 cm long and a displacement of 10 cm did not change anything.
As you have perhaps noticed it, the 60 mm propeller is too steam consuming, the 70 mm one is better but belongs to my friend Eric so my next plan now is to test a 72 mm two blade propeller bouht in China, when it arrives...
Raphaël
KNO3
« Reply #24 on: July 27, 2021, 10:44:44 am »
Try 3 or 4 blades and of course, as large as possible. 2 blades are better suited for fast revving electric motors.
Page created in 1.647 seconds with 21 queries.
