Well, as I've been mentioned by name in this thread (even if it was misspelled) some extra comment is perhaps worthwhile.
I agree that as supplied, cellulose dope is usually too thick to use directly. I usually thin it to something like a 50:50 mix. I bought a gallon can of thinners from a local motor factors many years ago and have yet to empty it.
The strength of dope is that the first thinned coats of dope do penetrate into the balsa and start the sealing and strengthening process. Light sanding removes the "surface fuzz", the dope having made the feathery surface fibers stiff and sand-able. The subsequent coats of neat dope seem to dissolve into the previous coats and produce an excellent bond before drying, which seems much better than just drying on the surface.
The use of tissue is to both strengthen and produce a smooth surface. I agree it doesn't make a balsa hull indestructible but it limits any accidental damage. I bought a couple of rolls of model aircraft tissue a couple of years ago, this is much better than the stuff sold for wrapping things up.
Corners can be tackled by sanding/trimming the excess away or folding the tissue around it, a 1/4-1/2 inch (6-12 mm) width is usually OK. I've found it is usually best to "feather" this excess by cutting it in to short lengths before doping into place. It makes the process easier and avoids creases (a problem on curved corners).
It often impossible to cover a whole panel on a hull with a single piece of tissue (and usually bloody hard to avoid creases too!). A modest overlap between adjacent pieces is best, any slight "step" can be removed after light sanding and a couple of coats of dope.
As for cleaning the brushes after use, I never do! An idea seen in a magazine many years ago (Aeromodeller I think?) was to take a glass jar with metal screw-top lid and (after the contents had been used, washed out and dried of course!) pour dope into it plus any thinners if needed, and 1/2 -3/4 fill it. Before adding the lid, a hole was made in it so that a suitable brush could be pushed up and firmly wedged into place. The brush being positioned so that its bristles would be immersed under the dope. The brush being held in place and the lid made airtight with a fillet of something like silicone or mastic sealer. Now, whenever dope is needed, I reach for the jar, unscrew the cap and ready to go. The lid has always been airtight and keeps my hands dope free should anything run down the handle.
As for leaving the inside of a wooden model unsealed, it seems to work as my three oldest models, one almost 50 years old, the other two well into their 40's, are still sound. Give me an hour to refit some batteries/receivers and they are ready to sail. But, if you don't seal the outer hull surfaces, have leaks, fail to check for and repair damage plus leave water inside the hull between sailing sessions, then sealing the inside might prolong the life of your model.
Glynn Guest
[size=78%] [/size]
