I'm going to selectively quote Subculture from 17 May 2021 because I think my second point to DanielH is going to get lost.
I expect, as I think Subculture might, the number of buyer's for a second hand decaperm does not match longstanding messageboard posts.
...Don't know why, they were considered the dogs doo-daas back in the day, and boy were they expensive but totally outclassed by what you can get now IMO.
A decaperm had sufficient
torque to drive a scale prop by virtue of the reduction gearbox so you
would get a good sale price for a second hand decaperm in years gone by.
This is 2024, so just over a decade ago, a six-figure quantity of 55 turn Mabuchi RS555-32
55 was dumped on the surplus market at under $1 each. Importation of small retail consignments from the orient is more common too.
By virtue of the 555 magnet strength or air gap (it's nowt to do with their 55 turns!) the 555 will do the same job as a noisy 12 volt decaperm's geared shaft.
When I had cartons of 555 motors stacked to the ceiling I recommended to aquintance's they shouldn't get mugged into buying decaperms but I'd not encourage any to replace with a 555 to make a profit.
I wouldn't recommend replacing with a 3-wire brushless (sensorless) either. Until rotation is above a minimum speed there isn't an emf for a sensorless brushless controller to detect rotor positon and sequence output to the motor for controlled speed. They need to be started in brute force mode.
