Pages: 1 [2] 3 4 5 6 7 8   Go Down
Author Topic: Martin's Latest Projects .... fads, whimsy and distractions!  (Read 20519 times)
Re: New Projects ....
« Reply #25 on: June 18, 2021, 06:29:18 pm »
Any suggestions how to trim the matchstick to (rough) shape?
I've tried Secateurs& tin snips but both chew through the match rather than cut.....
« Reply #26 on: June 18, 2021, 07:27:47 pm »
Go to Amazon, there are several different types if you search for 'matchstick cutter'. The safety cutter is not in stock but someone might have one.
Failing this, a razor saw with mini miter box.
TheLongBuild
  • Build em, and play hard..
« Reply #27 on: June 18, 2021, 07:32:34 pm »
if already glued on then Sandpaper.
mrlownotes
« Reply #28 on: June 18, 2021, 10:33:31 pm »
I guess it depends on what tooling you have available.
Personally, if the matchwood is soft enough to cut well I would remove the bulk of the straight sides with a Stanley knife along a steel ruler (several multiple cuts in the same place, if necessary).
For trickier curves and cut-outs I'd use a combination of a handheld fretsaw with a V-plate in a vice for support, followed by files and sandpaper to get down to the outer black lines.
Good Luck Martin, I hope you find a method that works for you with the tooling you have at hand.
Bintur Ellenbach
« Reply #29 on: June 18, 2021, 10:53:48 pm »
TheLongBuild
« Reply #30 on: June 19, 2021, 12:05:08 am »
This should sort it..
« Reply #31 on: June 19, 2021, 02:53:24 am »
 {-)  .... but that does remind me, I bought one of those 'toy grade' disk sanders from Lidl a couple of years back..... let me see if I can find it!
Stuw
  • slow motion modeller...
« Reply #32 on: June 19, 2021, 11:22:43 am »
Wow. This is frustrating me and I’m not even building it! Very fiddly...
2 Lesro Javelins... and that’s it. Not even close to finished!
« Reply #33 on: June 19, 2021, 11:25:17 am »
   O0    .....  one hour building .... 45 minutes peeling PVA off me fingers!   {-)
 ... actually loving it!    I like the single material idea, just wood .... and gallons of glue!
Andy M
« Reply #34 on: June 19, 2021, 11:43:59 pm »
I like the single material idea too, having done the rubbing strips on my boat from stirrers, I was looking about for things to use them for, I wondered if I could manage to build a small tender for the boat, planked with stirrers.
Thats another project though.
Enjoying watching your cabin cruiser progressing, I was wondering if you were going for any  motorisation or rc?
I had a couple of Hobbies outboards years ago, they really benefitted from having the prop blades whittled/sanded to a better profile and the bracing bits mostly removed.
Andy M
« Reply #35 on: June 20, 2021, 12:39:09 pm »
My wife made this matchstick furniture for my Vivacity  (Mary Jane), I thought it was good for a first ever attempt at making something out of wood.
« Reply #36 on: June 20, 2021, 12:49:05 pm »
     :o
« Reply #37 on: June 21, 2021, 11:09:16 pm »
Trials of Trimming
So far, I've tried:
Multi Angle Miter Shears (Amazon) -
Only good for loose matches & short cuts.
Garden Secateurs:
OK but you need a really good set & the curved blades tends to curve the wood as it cut and easily breaks the flat match sheets.
Weird curved scissors:
Bit flimsy and like the Secateurs the curved blades bends & crack the wood as it cuts.
Electrical 'flush cut' wire cutters:
Quite good bur can only cut one or two matches at a time .... and the shrapnel flies of at 300 MPH!
Evil look 'surgical shears'.
I think I got these from Proops, years ago...
Straight blade cuts very well but wood like to try anything similar.
« Reply #38 on: June 21, 2021, 11:19:28 pm »
Matchstick Cabin Cruiser - Part 3 - Doubling the keel... then doubling that!
« Reply #39 on: June 22, 2021, 03:31:10 am »
If you are cutting panels of pre glued matches, I would suggest a razor saw (or even a small Japanese style cross cut saw) and a final trim with a sanding block. The razor saw would be my choice as it is a back saw (the back of the blade is braced), and they are cheap as chips.
I would also make myself a mini bench block out of scrap wood.
« Reply #40 on: June 22, 2021, 04:02:22 pm »
Ordered one of these... "hobby" grade but should do the job.
« Reply #41 on: June 22, 2021, 05:56:49 pm »
I have the Chester version would not be without it, trims finger nails too  O0 O0 O0
« Reply #42 on: June 23, 2021, 07:05:06 am »
I suppose you couldn't find the toy grade sander then
« Reply #43 on: June 29, 2021, 08:16:58 pm »
OK, I've been building up the bulkheads over the last week or so, no real problems so far....
« Reply #44 on: June 29, 2021, 08:24:50 pm »
The next stage is fixing the bulkhead to the keel, which I haven't started yet, I've still not got the disk sander sorted out as yet.
So press on, the next stage is the Chines.
Now am I right, the chines are the longitudinal beams that hold the hull shape ? ( red arrows )
If so, the boat is about 400mm long, the instruction say 300mm ..... what have I got wrong?
« Reply #45 on: July 02, 2021, 04:57:58 pm »
Part 4 ....... Uploaded it, forgot to make it Live!   {:-{
Andy M
« Reply #46 on: July 03, 2021, 12:00:10 am »
A fretsaw with a fine toothed blade would be good for cutting them out. I have the motorised version but I think just hand operated for the controllability factor, mine cuts a bit too fast in thin or soft wood. I noticed Hobbies stocks a good range of blades.
BrianB6
« Reply #47 on: July 03, 2021, 03:05:56 am »
Try a Jewellery suppliers for very fine blades but buy them in quantity as they break easily.  >>:-(
tonyH
« Reply #48 on: July 03, 2021, 10:08:45 am »
Frazer Heslop recommended Cousins https://www.cousinsuk.com/category/cutting-saws-hack-piercing-scroll and he's very right! I used their piercing saws for some ali and I've no doubt about their quality.
No commercial connection!!
« Reply #49 on: July 03, 2021, 09:53:45 pm »
Matchstick Cabin Cruiser - Part 5 - Bent Keel & Bulkheads!
Pages: 1 [2] 3 4 5 6 7 8   Go Up
Page created in 0.109 seconds with 21 queries.
