Author Topic: Sheerline dive system  (Read 2263 times)
terry1956
« on: June 08, 2021, 07:12:48 pm »
Hi out there. I just purchased a sheerline submarine. The fault with the sub is the dive system. The submarine dives, but unless the water pump is running the sub will surface. My understanding is that the valve that keeps the water in the dive tank is at fault. Can anyone please explain to me what too test and check for, thanks
gra2
Re: Sheerline dive system
« Reply #1 on: June 09, 2021, 10:17:16 am »
Google Becks Model Marine in the UK.
They are the new home of Sheerline Submarines he should be able to help you.
Graham
terry1956
« Reply #2 on: June 09, 2021, 10:39:38 am »
Subculture
    • Dive-in to Model submarines
« Reply #3 on: June 09, 2021, 05:18:57 pm »
Google sheerline pinch valve will bring up a host of info. It’s a very basic system.
gra2
« Reply #4 on: June 10, 2021, 06:17:06 am »
If you send me a pm I will send you some info to fix your problem.
Graham
terry1956
« Reply #5 on: June 11, 2021, 09:32:27 pm »
Pm send, thanks for offer of help
gra2
« Reply #6 on: June 13, 2021, 10:20:41 am »
Hi terry1956 If you pm me your email address I will send you some info that should help.
Graham
terry1956
« Reply #7 on: June 14, 2021, 04:13:08 pm »
Hi can you please send to my new address, I just can’t excess my old one any more. I have pm you my address
admiral donuts
« Reply #8 on: July 08, 2021, 07:00:41 pm »
The system uses a pinch plunger and ball bearing to crush the silicone tube closed , the servo has a cam carved from a standard servo disc, full transmitter lever one way activates the water pump via a micro switch at the same time the pinch pressure is removed from the plunger , releasing the lever restores pinch pressure , it is possible that cam disc is worn or the silicon tube has worn , the tube runs through a cross drilled plastic block containing a plunger , tube and ball bearing , sometimes water will be retained in the ballast tank , blow into the tank via the silicone tube , this increases the air pressure in the tank and forces out any remaining water , hope this helps
Page created in 0.157 seconds with 21 queries.
