Author Topic: La Louise - KBIO.  (Read 1456 times)
KBIO
La Louise - KBIO.
« on: June 11, 2021, 05:45:10 pm »
Around 1870 , in the extreme west of the Brittany, the transportation  of people and the goods between Brest and Molène & Ouessant was made by locally built sloops of +/- 10 tonneaux.Due to the strong sea currents , strong winds and vicious reefs the travel between the continent and these islands was particularly dangerous .Sailing between The Conquet and Ouessant takes about 3 to 4 hours in good conditions.
It can take more than 12 H00 when the weather is bad.26 April 1876 shipwreck of the St Jean = 23 drawns , almost women from Ouessant.12 March 1877 . After 13 years of good service , the Marie-Hortense belonging to postal services sank with no survivors.The 15th April 1877 her replacement sank also.Modern times arising, it has been decided to build a steamer to replace the sailing ships. The first one gauged 26 tons propelled by a a 23 CV steam machine sailing  up to 6 knots Her Captain «  Le père Miniou » was famous and has provided the service between the ilsands for 29 years.Washed out by so many years fighting the sea, she was removed from service and let roten as a pontoon-livewell in the Brest’ harbor.In tribute  of this sloops and their sailors I thought  that it worst to tell you their story before to present my Louise whose the original was in service from 1881 to 1924!Missing some details as usual as I am suffering of an endless and chronic stream of procrastination. :-) - 110 cm long , for a weight of 8 kg, she is propelled by an early Anton OS203- 3 cc and a 60 mm/3 blades propeller.The boiler and the burner/gas tank are also from Anton’s begining. I sailed this boat 3/4 times within 30 years and apart from the burner’s jet partially plugged through the years, the assy works perfectly : adding oil and steam and it makes my day !Hope you like it.
https://youtu.be/RmriexK_Z5E
rhavrane
  • Steam passionate collector
Re: La Louise - KBIO.
« Reply #1 on: June 11, 2021, 07:30:16 pm »
Bonjour
Nice boat indeed, and (Yves, don't help) do you have any idea of the function of the small cabin in the port bow  ok2
Raphaël
KBIO
« Reply #2 on: June 16, 2021, 08:59:56 am »
I forgot ! %)
« Reply #3 on: June 16, 2021, 06:19:53 pm »
Starboard bow unless the picture has been reversed  :-))  (my guess its the "head" /toilet for land lubbers  {-) {-) {-) )
Page created in 0.5 seconds with 17 queries.
