Hi all, would like to give my diagnosis of my fault and see what the team thinks and my options.
Took HMS Bristol for a run saturday, first time with two batteries, both same voltage and amps and charged, on the bench all woked, as soon as she left the side all dies, eventually got her back. First though new battery might be duff, but not likely, both charged and fitted in today on the becnch. All worked, foghorn extra loud, but notice props seemed a bit slower. Turned off for lunch, came back turne on all working for about a minute, then a fain sound like "pop" and total shutdown, BUT no burning board smell. All fuse intact, disconnected the twin esc, which came from hOwes several years ago, no idea of make at monet and think rated at 50amps. Plugged a rx batt pack in and all function from all electronic board and relays., plugged 1 esc back in (one with threee wires, switched on and the voltage reg picked up its 1.5 volt (radar motor) and again alll works, even manged to turn port porp, rpeated it for the other esc, no lights at all and no power to prop. Diagnosis is the esc is shot. If so would you replace like for like, or bite the bullet and replace with something like mtroniks.
