Thus far I have identified that the Los Angeles museum has a copy of the original lines & offsets drawing in the Fellows & Stewart collection, but they are not accessible for some time due to renovations. I am sure there many copies of them around the world, at the very least one per boatyard that built 63's (well over 20 yards), but unless someone was planning to build a hull and needed them for lofting they may not even realise how important they are.
UScrashboat.org site has a collection of framing photos of the MKII build from the Booth Bay Historical collection. The hull is the same only the internal fit-out varies with the lower pilot station replaced as a radio room.
There were several variants with a combination of straight shaft and Vee drives subtly modifying the dispensary cabin, from the 127, 152, 168, 252, 314 & 293 even a 416 fire boat. The MKII has no lower helm, the MKIII has an opening transom that changes the aft cockpit.
Photos show many variations from 1941-1968 of the 63's, without considering refit conversions, but all 63 variants I have found relate to fit-out changes and the hull design remains. So there must be more copies of the lines & offsets to be found, if only someone has it digitised, although I would gladly do that.
I have reconciled the "15' molded beam" vs the "15'6" beam (max over the guards)". So the 42 bulkhead is 15" beam overall plus the inner planking at 7/16" + outer at 9/16", leaving 2" for the guard rail each side.
Now on with the 1:20 half model build to confirm my guesses, whilst I wait for the lines plan before the full model.
