Is there a dedicated thread to the revel 1/72 kit please ?
Yes, any air fill with foam.
I have made a start with deck removed so access can be made via removable parts of the superstructure, having tall combings so any water in deck flows out thru the scuppers rather than into the boat.
I will made the rudder and steering easy to remove for prop shaft servicing, and still be a dry boat.
The lake can get quiet choppy and the boat needs to be dry.
A test will he boat floating in the bath and "shower" tested for water ingress. In my opinion it must pass this test.
All boats I have made so far have past this test, the Lesro did suffer from slight water ingress, a few drops, thru the sheet holes, and did get some condensation which was easy to deal with.
Not sure about prop shaft yet as it's gunna be difficult to arrange for the inboard end to be on it above the waterline.
Maybe a bulkhead arrangement and toothed belt drive from motor, a lid, so if water makes its way in it will be contained in a box....n nt sure yet. I use Castrol lm grease filling the stern tube which work well in the sea rider etc., But the inboard ends of Thier stern tubes are on it ever so slightly above the water line.
