Pages: [1] 2 3 4   Go Down
Author Topic: HMS Victtorious  (Read 27181 times)
Rob47
HMS Victtorious
« on: August 10, 2021, 10:09:20 pm »
Couple of images of latest build, constructed the way I now like best, keel frames, no stringers and no screwing to the bench, for the first time i have used liteply from SLEC in 2mm thickness, soak it for 30 mins in warm water then pin it to the frames, let dry then remove and any final trilming, it leaves a perfect shaped plate that only rewuires gluing.  Bilit one side complete and now warping or distortion, very happy with it,  Its 1/144, so if anyone knows of Buccaneer or Gannets in that scale give me a buzz
I will finish this model
KitS
Re: HMS Victtorious
« Reply #1 on: August 11, 2021, 07:55:34 am »
Wels Models do vacforms of the Bucc and AEW Gannet in 1/144, but they're the only game in town AFAIK.
Kit
frogman3
Re: HMS Victtorious
« Reply #2 on: August 11, 2021, 09:36:03 am »
HI Bob im confused how many carriers are you buildng at the moment an why ?as it took me 7 yrs just to build my NIMITZ carrier as by then i was pooded
chris  :o
tonyH
Re: HMS Victtorious
« Reply #3 on: August 11, 2021, 11:33:31 am »
frogman3
Re: HMS Victtorious
« Reply #4 on: August 11, 2021, 02:33:14 pm »
HI Bob im confused how many carriers are you buildng at the moment an why ?as it took me 7 yrs just to build my NIMITZ carrier as by then i was pooped
chris  :o
Re: HMS Victtorious
« Reply #5 on: August 11, 2021, 03:42:51 pm »
You have made a great start Rob!
raflaunches
  • The Penguins are coming!!!
Re: HMS Victtorious
« Reply #6 on: August 11, 2021, 07:22:49 pm »
Very impressive :-)
Looks every part the HMS Victorious I’ve seen in many books. If I find any 1/144 scale aircraft I’ll pass them your way.
Nick B
Illegitimi non carborundum!
Rob47
Re: HMS Victtorious
« Reply #7 on: August 11, 2021, 09:24:15 pm »
chris  :o
Chris not sure why you are confused, but building Victoroius and finishing Leviathan in the bckground.
You need to get on and plank Tigers quarter deck, plenty of bull there {-) {-) {-) {-)
Rob47
Re: HMS Victtorious
« Reply #8 on: August 11, 2021, 09:26:39 pm »
Depends on how much you want to spend! Gannet AEW resin as bonus in this one from Hannants at £90.00! https://www.hannants.co.uk/product/ANIG4050?result-token=mSKI2Welsh Models, again via Hannants, do gannet and bucaneer at about £18.00 each https://www.hannants.co.uk/product/WHPJW08?result-token=mSKI2 and https://www.hannants.co.uk/product/WHPJW16?result-token=mSKI2
They're the vacforms that Kit posted.Shapeways do a buccaneer for about £18.00 as well https://www.shapeways.com/product/KWS3PCMK9/blackburn-buccaneer-s-2?optionId=181901408&li=marketplaceThere are a couple of Gannets as well AS1 and AEW3 https://www.shapeways.com/product/UG3J5JE24/fairey-gannet-aew-3?optionId=182884965&li=marketplace or https://www.shapeways.com/product/SZAL66ZAH/fairey-gannet-as-i?optionId=182885375&li=marketplace
Tony dont think I will go for the resin gannet as its two kits and Nimrod would look out of place.  I know about Welsh Mods, bu vac form and i do not seem to get on  {-)   Saw Shapeways Bucc so for the same price as vac I can have ready built.  Thanks for the input.
tonyH
Re: HMS Victtorious
« Reply #9 on: August 12, 2021, 08:45:48 am »
Glad to be of service! The Shapeway ones look to be pretty good, especially the Gannet AEW3. Hannants do loads of job-specific decals as well.
Tony :-))
Rob47
Re: HMS Victtorious
« Reply #10 on: September 27, 2021, 03:53:24 pm »
Shots showing how Victorious hull has come on.  Basic shape and center shaft and rudder all fitted, now waiitnig to coat it with the finishing gel coat to seal it all.  Then a start on the island as that will be plastic and can be done indoors now winter approaches.
Re: HMS Victtorious
« Reply #11 on: October 09, 2021, 12:34:22 pm »
It amazes me how you get ply to form into such shapes. It's a bit like forming car body panels without the useful stretching of the metal.
raflaunches
Re: HMS Victtorious
« Reply #12 on: October 09, 2021, 12:46:09 pm »
Looks fantastic Bob, I’m sorting a few pieces for the CVA-01- mainly deck edge netting- my God there’s a lot of it!
Nick B
Rob47
Re: HMS Victtorious
« Reply #13 on: October 10, 2021, 03:23:50 pm »
Nick
The drawings do not show a lot of it so you can be selective I think {-)
Rob47
Re: HMS Victtorious
« Reply #14 on: October 10, 2021, 03:30:51 pm »
This is the finished hull, before I start to detail.  My methode of building seems to have worked very well and produced a hull which is as strong as fibreglass, but without the mess.  Keel and frames built on flat surface but not fixed, 2mm litepley soaked and pined to shape, when dry it produces a shaped piece that will not starighten out, once all hull sheeted it was covered with Homebases finest, ready mixed plaster, then rubbed down to give nice smooth coat.  I was adamnat that not a drop of fibreglass was to be used.  Coated the hull with three coats of expoxy finishing resin as reccomended by the maunfacturer.  Set rock  hard and is easy to work.  At this rate she may get her flotation trials earlier than anticipated.
The shadows make it look as if there is a narrowing of the stern then it levels out again, this is just an illusion %%
Re: HMS Victtorious
« Reply #15 on: October 11, 2021, 09:09:59 pm »
I'm not a fan of fibreglass and so seeing different alternatives to it are always gladly studied. Steve, Nick's Dad has an alternative method to Fibreglassing as well that I am looking at.
Rob47
Re: HMS Victtorious
« Reply #16 on: December 07, 2021, 09:48:19 pm »
Small update, have managed to get forward part of flight deck illuminated, the distribution board is brilliant and @£10 worth it, running 3mmm 3v LED from 12v source and each bank has varaible lighting, makes eventually for a very tidy lighting loom.  Very pleased with the result.  Just need to brave the cold and take it back to the hull.
frogman3
Re: HMS Victtorious
« Reply #17 on: December 08, 2021, 06:36:59 am »
HI Bob well she's looking good with the deck lights on an will you have bridge lights on her an that pdb looks the bussiness  an from what i gather its 12v in but you can alter the voltage comin out ? an im now gonna look right through your build as cant remember much about it an glad your wireing is goin better than mine but im gradulaly getting back on track an when my main H/J plug turns up then i can have another go at getting the wireing right but you are doin great Sir keep it up as i'll be following along  :-))
chris
Geoff
Re: HMS Victtorious
« Reply #18 on: December 08, 2021, 02:50:11 pm »
Interesting and can you supply details of the PCB board where and when you purchased it as it looks kind of neat. Is the input voltage also variable?
Geoff
T888
Re: HMS Victtorious
« Reply #19 on: December 08, 2021, 04:08:18 pm »
Bob,
Will nice to see her on the water at dusk fully lit up  :-))
Regards David
South Coast Modellers
Rob47
Re: HMS Victtorious
« Reply #20 on: December 08, 2021, 09:11:04 pm »
Geoff
Geoff
If you search layouts4u you will find it there, its a model railway site but the service is amazing, I asked if it would do what I thought so they wired one up and tested it, also sent a question on a Sunday and got a reply that night, the board will go to 16 v.  The LED I am using are 4 @12v and remained 3v, no need to change any settings at all, except the brightness. I am chuffed to bits with it.
Rob47
Re: HMS Victtorious
« Reply #21 on: December 08, 2021, 09:11:34 pm »
Bob,
Spot on there Dave, think it will look good
Rob47
Re: HMS Victtorious
« Reply #22 on: December 08, 2021, 09:12:14 pm »
chris
Cant alter the voltage but am running 12 v and 3 v from the 12v input.
johnv
Re: HMS Victtorious
« Reply #23 on: December 08, 2021, 11:05:52 pm »
All looks very nice Bob. Glad you are getting back in to it. Keep up the good work
frogman3
Re: HMS Victtorious
« Reply #24 on: December 09, 2021, 04:55:49 am »
HI Bob yes that latouts4u is very good shop as thats where i get all my 2mm leds from an as you say very good sevice an yes she will look good lit up on a twy
light sail same as my tiger bob as ive now getting my lights to work on tiger
chris
Pages: [1] 2 3 4   Go Up
Page created in 0.017 seconds with 20 queries.
