Pages: 1 [2] 3 4   Go Down
Author Topic: HMS Victtorious  (Read 18449 times)
Rob47
Re: HMS Victtorious
« Reply #25 on: January 31, 2022, 03:51:36 pm »
Working forward lift on HMS Victoroius, mad as a module so can be directly fitted to the underside of the deck, when fitted none of the shafts will be seen just the deck.  Some detailing on the side to do then a lick of paint and it can be fitted
IMG 1466 - YouTube
IMG 1467 - YouTube
I will finish this model
Rob47
Re: HMS Victtorious
« Reply #26 on: February 01, 2022, 09:09:23 pm »
The sound module for Victorious, 8 thracks on a removable recordable SD card, amazing size and no amp needed, loud and clear sound
Re: HMS Victtorious
« Reply #27 on: February 01, 2022, 09:16:56 pm »
I like how you got the motors balanced so the lift platform is level.
Nice :)
Rob47
Re: HMS Victtorious
« Reply #28 on: February 01, 2022, 09:27:48 pm »
Thanks not easy, but worth the time and patince
frogman3
Re: HMS Victtorious
« Reply #29 on: February 02, 2022, 05:32:05 am »
HI Bob what sounds are on this unit  ?  an are they already fitted on ? or do you have to fit them yourself ? an where did you get this unit ?
chris
Rob47
Re: HMS Victtorious
« Reply #30 on: February 02, 2022, 10:12:54 am »
Chris
Model radio workshop, best electronis in the game as far as I am concerned
Sounds already on the SD card, but you can take it out and add anything you wanti fyou know how.
Foghorn, action alarm, pipe, (cant recal which call it is though) and gun fire.  This is a 5 version that I had to test for mike, the production versions are on the website.
HTH
All wll your end I hope
dodes
Re: HMS Victtorious
« Reply #31 on: February 02, 2022, 04:04:47 pm »
If know anyone who can play the bugle call I can email them to you.
dodes
Re: HMS Victtorious
« Reply #32 on: February 02, 2022, 04:07:59 pm »
Better phrase that better, I have the written notes for the bugle calls, if you know someone who can play a bugle for you, capital ships in days past used to a marine bugler to make the calls over the ships P.A. system.
dodes
Re: HMS Victtorious
« Reply #33 on: February 02, 2022, 04:18:52 pm »
Trying to attach action stations
Rob47
Re: HMS Victtorious
« Reply #34 on: February 10, 2022, 11:12:36 pm »
At last forward part of flight deck secured just needs to be trimmed, island started along with funnel and main mast
frogman3
Re: HMS Victtorious
« Reply #35 on: February 11, 2022, 09:59:37 am »
HI Bob lookin really good with the lights on the flightdeck brilliant work an should be visable in daylight an in a model show if you fit her in
ATB
CHRIS  :-))
T888
Re: HMS Victtorious
« Reply #36 on: February 11, 2022, 02:35:31 pm »
Bob,
Flight deck lights very nice  :-)) :-))
Regards David
johnv
Re: HMS Victtorious
« Reply #37 on: February 12, 2022, 11:32:23 am »
Very nice job as always Bob. Pleased your getting on well with your build cheers John v
Rob47
Re: HMS Victtorious
« Reply #38 on: February 12, 2022, 03:37:56 pm »
Thanks John
Re: HMS Victtorious
« Reply #39 on: February 14, 2022, 09:42:48 pm »
Great work on the lighting. The island is starting to look fab as well.
Rob47
Re: HMS Victtorious
« Reply #40 on: April 16, 2022, 07:16:22 pm »
Well at last the flight deck lighting is complete, and starting to build up the air wing
frogman3
Re: HMS Victtorious
« Reply #41 on: April 16, 2022, 10:07:02 pm »
FANTASTIC lighting Bob very well done
chris  :-))
johnv
Re: HMS Victtorious
« Reply #42 on: April 18, 2022, 06:40:42 pm »
Hi Bob you are getting good with the lighting. All in line as well can't be bad we'll done. And hope you are keeping well. Not doing to good myself. Cheers J v
Re: HMS Victtorious
« Reply #43 on: April 18, 2022, 09:53:16 pm »
Looking fab Rob! I agree that the straightness of your lines (lights and paint) is impressive.
Tworrs
Re: HMS Victtorious
« Reply #44 on: April 19, 2022, 05:48:25 am »
She looks stunning all lit up.
Rob47
Re: HMS Victtorious
« Reply #45 on: April 19, 2022, 01:22:52 pm »
The way I do the lines is I sprayed the whole deck matt white, then using variuos widths of masking tape sparayed to the other colours over it, remove tape and nice straight lines.  If I d them freehand well less said about that
frogman3
Re: HMS Victtorious
« Reply #46 on: April 19, 2022, 03:23:33 pm »
YES Garry she does Bob is doin a great job on her
chris  :-))
Rob47
Re: HMS Victtorious
« Reply #47 on: April 24, 2022, 03:39:30 pm »
Tis the season for doing silly things with helicopters.  This one of the Wessex that will grace Victorious flight deck, the model is from Mark one models and not three bad.
Re: HMS Victtorious
« Reply #48 on: April 24, 2022, 04:41:08 pm »
Ah yes. I did similar for the waterline on my destroyer. saves a lot of faffage.
frogman3
Re: HMS Victtorious
« Reply #49 on: April 25, 2022, 06:27:16 pm »
AHA well done Bob with the motor fitted in should look good goin on the flight deck an are you gonna get the tail rotor to go as well ?
chris
Pages: 1 [2] 3 4   Go Up
Page created in 0.018 seconds with 18 queries.
