Thank you soo much for these answers.
I haven't done the calculations on current through receiver and was more "going with the guts" but thinking about it one more time tells me you're calculations are probably correct.a
I am glad of an opportunity to explain the potential hazard due to risky wiring practice, which it is without ferrite toroid or opto-isolation remedy.
The finite cable resistance is what people forget in this situation.
15cm of 16awg from esc to the Y-junction would give 0.002Ω and 30cm of 22 awg of each servo cable would be 0.016Ω making the desired route of 0.002Ω in parallel with ((0.016+0.016+0.002)= 0.034Ω) or leading to the 5% backdoor current. One of the forum examples had many parallel connections which makes the hazard even worse.
I definitely have to check up on this.
I'm not exactly sure were talking about the same thing here. Having one ESC only connected to batt +&- and signal wire to receiver while having the other ESC connected to the same battery and all three wires to receiver should work(I haven't tried).
But again, thank you so much HMS Invisible for your input.
The
esc signal noise diagram is what you can get on the esc inputs from a high drain motor and long supply wires.
I understood you to mean unhook the negative in the non-bec esc's servo plug to break the loop to leave only white. It may break the loop but it makes the noise signal even more horrendous. The mid way situation is a 10kΩ so try a resistor first.
At least you understand that wire resistance gives rise to a problem with a threshold level and that is where my
try 555 motors comes from. Also consider that unless an esc is switching above 10kHz it is switching the motor stall current on/off at part of the throttle range.
Other things worthy of note is rc receivers don't all send pulses of the same amplitude and some inexperienced esc, and other rc, product designers would use crude pulse counting (and don't even think of using edge triggered timers with induced signal line noise!) where others have an artificial intelligence routine to effectively sift out a signal from background chatter. This is what I did on migrating to microcontrollers. While both esc makers could claim to have software glitch filtering the former would ineffective at filtering out signal line noise from sharing a battery. So even a change in rc set and esc brand as well as wire lengths can make all the difference to whether it works or not.
