Author Topic: Another question !  (Read 2095 times)
KBIO
Another question !
« on: September 10, 2021, 03:57:23 pm »
Hello !
I have a boiler with is looking good and well manufactured but I do not know who is the manufacturer.
150 mm high by 85 mm dia.
Any help on this matter would help. Also , what the burner size used ?
The good thing in it is the super heater which is inside the boiler. I know that M.Bayliss use the same technic on his last boilers , nobody else that I know.
Subsidiary question : what paint are you using for painting an engine. (heat resistant ) ? And what colors are available for that ?
Thanks a lot for your collaboration .
Best regards.
KBIO
Re: Another question !
« Reply #1 on: September 11, 2021, 01:02:48 pm »
Hello !
I think that it is a Max Hemmens.
Any other idea ? %)
KNO3
« Reply #2 on: September 11, 2021, 04:13:10 pm »
Looks like a Cheddar to me, could be the Proteus vertical or the Puffin vertical.
DBS88
« Reply #3 on: September 11, 2021, 06:27:14 pm »
Hi have had a quick look in the Cheddar catalogue and agree its most likely a vertical Proteus, here is a photo, the smaller boilers only had two brass bands. In addition the chimney and the safety valve appear to be the same as yours.
KBIO
« Reply #4 on: September 11, 2021, 06:34:26 pm »
Hello !
Thanks a lot  !
I think that you guys are right ! It looks exactly like mine with the steam exhaust on the top side. After a long trip trough the super heater.
Now, I need to know what size jet , I need to use. I would go for N° 8 - .25 mm / 90 gr/h .
But if you can confirm , I would appreciate.
Regards.
DBS88
« Reply #5 on: September 11, 2021, 07:23:00 pm »
Yes gas jet No 8 set so there is a 4.5mm air gap for induction of primary air
KBIO
« Reply #6 on: September 12, 2021, 08:18:14 am »
Thank you ! I ty that !
