Author Topic: Harro Koebke  (Read 375 times)
6705russell
Harro Koebke
« on: September 10, 2021, 05:54:40 pm »
Another kit I have ready to build around Christmas time is the Harro Koebke, this is a KYModels kit and to be honest it’s the best kit I have seen in a good few years, the hull and deck are 2-3mm thick and it is rock solid all through, there are around 500 fittings, daughter boat “Notariius” is included along with her jet drive, there is all the running gear including motors but will install brushless in this one, the fittings quality are second to none.
6705russell
Re: Harro Koebke
« Reply #1 on: September 10, 2021, 05:55:55 pm »
Daughter boat.
6705russell
Re: Harro Koebke
« Reply #2 on: September 10, 2021, 05:56:39 pm »
Jet drive.
6705russell
Re: Harro Koebke
« Reply #3 on: September 10, 2021, 05:57:19 pm »
Fittings.
C-3PO
Re: Harro Koebke
« Reply #4 on: September 10, 2021, 06:32:30 pm »
Very nice - I have been after a kit of that boat for ages!!!
Where did you purchase it from?
Is the superstructure moulded as well?
C-3PO
Martin [Admin]
Re: Harro Koebke
« Reply #5 on: September 10, 2021, 07:13:57 pm »
6705russell
Re: Harro Koebke
« Reply #6 on: September 11, 2021, 11:44:54 am »
C-3PO
The kit is from KYModels, apart from the hull and deck being pre-joined everything else is built up from the supplied plasticard/abs, I ordered the biggest Raboesch bow thruster with the brass props yesterday but there is also a thruster supplied in the kit..
6705russell
Re: Harro Koebke
« Reply #7 on: September 11, 2021, 11:49:05 am »
Aluminum detail.
6705russell
Re: Harro Koebke
« Reply #8 on: September 11, 2021, 12:16:18 pm »
And the gold plated propellers  %)
Perkasaman2
Re: Harro Koebke
« Reply #9 on: September 11, 2021, 05:29:22 pm »
This is an excellent kit. What are the hull dimensions? It looks like a large sized hull.
6705russell
Re: Harro Koebke
« Reply #10 on: September 11, 2021, 05:53:30 pm »
1150 length by 280 width, daughter boat is 280 length, 111 width
Perkasaman2
Re: Harro Koebke
« Reply #11 on: September 12, 2021, 04:49:27 pm »
Wow that is a big boat at 45" x 11" and it will present well on the water. Like you I prefer larger models and find them easier to work on.
6705russell
Re: Harro Koebke
« Reply #12 on: September 12, 2021, 04:54:22 pm »
Yes I like the bigger boat but they play havoc with my back, luckily there are some good guys who get down the lake who will give me hand..
Perkasaman2
Re: Harro Koebke
« Reply #13 on: September 12, 2021, 06:48:04 pm »
Like you I have a back problem. I used to use two slings with handles/spreaders to transfer the boat from the cradle to the water and vice versa. This was doable with care. Lifting the boat and cradle up and down from ground level was the biggest risk. I redesigned the cradle to have extra width and also have slings fore and aft.
I am looking forward to your build.
