Author Topic: VOLANTEX RACENT HURRICANE SAIL YACHT BOAT 1M RC  (Read 346 times)
terryyacht
« on: September 11, 2021, 03:37:39 pm »
VOLANTEX RACENT HURRICANE SAIL YACHT BOAT 1M RTR
The Hurricane is a large 1m length sailboat and measuring in at 213cm tall (tip to balast) it is a impressive model. Coming mostly factory assembled, the blow moulded ABS hull features a sealed radio box that houses a 2.4ghz radio system, winch and rudder servo and Li-ion receiver battery. Most of the rigging is completed at the factory, leaving final assembly and mounting of the printed nylon heavy-duty sails a relatively quick affair. If you are looking for the ultimate r/c sailing experience, sail with the Hurricane.
FEATURES & SPECIFICATIONSReady-To-Run
  • 2.4ghz radio
  • Rudder Servo
  • Printed nylon sail
  • Hull Length: 995mm
  • Beam (Width): 220mm
  • Height from bottom of hull: 790mm
  • Height from bottom of ballast: 2130mm
  • Weight: 3.15kg
  • Hull Material: ABS Plastic
  • Ballast Material: Iron
  • Ballast Weight: 1.7kg
  • Jib - 2500 sq cm
  • Main - 3550 sq cm
  • Total - 6050 sq cm
  • Boat is brand new having been assembled for photos and checking everything works as it should
  • It is complete with transmitter and receiver with batteries and charger for onboard battery, transmitter takes AA batteries
  • Cannot upload photos, dont know why but will email if you leave email address
Looking for 130
Sailing is always a challenge and every voyage different
Re: VOLANTEX RACENT HURRICANE SAIL YACHT BOAT 1M RC
« Reply #1 on: September 11, 2021, 07:25:19 pm »
           Now put the PRICE
terryyacht
« Reply #2 on: September 12, 2021, 07:31:55 pm »
Item now sold thanks
