Technical, Techniques, Hints, and Tips > Modelling tools
Best tools for removing work hold tabs form CnC cut plywood parts
(1/1)
dillinger 04:
Hello everyone
I am currently working on a wood model boat kit, I have removed the work hold tabs, from the 3mm plywood sheet parts, and ready to finish up removing what is left behind of the tab parts remaining. Any expert advice experience for best tools to use to do the job right as for good clean results would be appreciated
David
[size=78%] [/size]
Baldrick:
   My tool of choice for that is the Veritas low angle thumb plane but if you do not have one or wish to spend out £45 a nice sharp small chisel will do the job as well providing you are careful.
ukmike:
The wood seems to be lite ply, if so, then you can't beat a good quality Scalpel.
A Swann Morton handle No.3 with 10a blades is ideal.
Mike.
Navigation
[0] Message Index
Go to full version
