Pages: 1 [2] 3 4   Go Down
Author Topic: Offshore Tug/Supply build Union Fighter/Wrestler  (Read 17487 times)
chipchase
Re: Offshore Tug/Supply build Union Fighter/Wrestler
« Reply #25 on: October 08, 2021, 07:21:38 pm »
Every Pictures a learning curve for me better then reading a book on model making.
                Regards Howard.
Im pleased your enjoying the build and the photos Howard.
chipchase
« Reply #26 on: October 09, 2021, 08:42:44 pm »
Finished fitting the keels today filled and sanded.
chipchase
« Reply #27 on: October 09, 2021, 08:57:05 pm »
After finishing the keels I started on the bracket for the bow thruster.
chipchase
« Reply #28 on: October 10, 2021, 07:07:10 pm »
A bit more done on the thruster motor bracket today, not much more to do before its permanently fitted into place.
chipchase
« Reply #29 on: October 11, 2021, 08:05:46 pm »
Further progress with fitting the thruster, I fitted a support bracket for the motor mount as the only thing that would be supporting it would be the grub screw. I decided to glass the thruster into the hull lets hope it won't need to come out at a later date LOL, I also decided to  give the hull an extra coat o resin while I was glassing the thruster.
A small amount of filler was used on the thruster outlet and primer added to show any imperfections.
« Reply #30 on: October 12, 2021, 02:28:20 am »
Brian....
The bow thruster from Modelbau appears to be an excellent ..if not near industrial quality...[best on the model market?] is there a recommended input shaft speed relative to the [propeller] diameter/size and a recommended motor power input?
Your installation triangular mounting gusset and the fabricated brass section vertical bracket appears securely robust [but needed
What is the distance between water level & the axis of the thruster....~~150 mm?
We see the 'hefty' brushless motor, so is there a potential for 'scale' cavitation or will this be eliminated/minimised by a speed controller? ....would you only conclude cavitation by a discharge foam with bubbles, or an audible increase in motor speed?
6705russell
« Reply #31 on: October 12, 2021, 07:23:53 am »
I have two Bauer thrusters and must say the engineering is quality. Your build is looking well Brian.
chipchase
« Reply #32 on: October 12, 2021, 08:41:38 am »
Brian....
Hi Derek
The thruster is very well made, unfortunately no info is given regards motor power and shaft speed, I have had it up to 2500 rpm and runs very smooth.
Your spot-on regarding water level and axis 150mm :-))
The brushless motor is just one I had in stock that I posted just to show how Its fitted, I will be using a speed controller for the motor but if needed I will buy a new motor if needed,
(any recommendations regarding brushless motors would be apricated as I’m not up to scratch with these motors)
Brian
chipchase
« Reply #33 on: October 12, 2021, 08:52:54 am »
Cheers Russell I am quite enjoying this build, slowy getting back into the modelling. the thrusters are very well made as you say.
Brian
6705russell
« Reply #34 on: October 12, 2021, 03:14:10 pm »
Good on you Brian, I am stumped for a few weeks, just moved house so waiting for new garage/workshop to be built  <:(
chipchase
« Reply #35 on: October 14, 2021, 05:14:07 pm »
Not a lot done over the last couple of days just the anchor boxes made and fitted.
chipchase
« Reply #37 on: October 15, 2021, 04:47:14 pm »
Good day today, cooling water intakes made and fitted, tomorrow hopefully get a start on the stern roller box.
chipchase
« Reply #38 on: October 17, 2021, 06:30:51 pm »
A good couple of days working on the build, stern roller just about fitted. Anchor boxs cooling water intake boxes and stern roller laminated in.
I made spring loaded pins for the roller for easy fitting.
chipchase
« Reply #39 on: October 17, 2021, 06:34:05 pm »
A couple more photos showing boxes laminated in.
chipchase
« Reply #40 on: October 18, 2021, 07:09:24 pm »
Not a lot done today, but managed to start fitting the frames for the deck
« Reply #41 on: October 18, 2021, 11:48:51 pm »
Brian....
All of the internal formwork support appears to be a species of fast-growing Pine?........will it have a coat of some sort of waterproofing prior to sealing up?, and are you using an epoxy resin cement to adhere the timber to the black Gelcoat?
chipchase
« Reply #42 on: October 19, 2021, 08:27:44 am »
Hi Derek
The frame work is from my local DIY shop 12 x 12mm I have used this on many models over the years, i have never thought about waterproofing as I have never had a problem with this in the past  :-))  I have used laminating resin on the frames that are attched to the hull. I will be using a water proof wood glue on the rest of the frames. The black you see on the inside of the hull is laminating resin with a colour pigment added, I decided to give the inside of the hull a coat to help seal around the anchor boxes and cooling water intake boxes plus around the stern end roller, probably over the top and cosmetic to be honest  {-)
Brian
chipchase
« Reply #43 on: October 19, 2021, 06:55:27 pm »
Got a start fitting the 8mm half round rubbing strakes today, I managed to get 1000mm lengths for this job
Howard
« Reply #44 on: October 19, 2021, 07:54:11 pm »
Hello Brian,
 who's make was your Half round and how did you fix it to the hull as you may of seen in my SD14 build I have had huge problems with mine finding a glue that would stick it to plastic.
                      Regards Howard.
chipchase
« Reply #45 on: October 19, 2021, 10:07:08 pm »
Hello Brian,
                      Regards Howard.
Hi Howard
I bought the half round on line from Model Shop Leeds, the make is  Maquette the glue I use is Mitre Bond from Screwfix, I use this glue on all my builds and never had problems with it. I always give the plastic a light sanding before sticking. The glue is very reasonably priced,I normally buy the trade kit, it includes 3 50g bottles and a starter pen £14:99  :-))
Brian
chipchase
« Reply #46 on: October 19, 2021, 10:24:22 pm »
Howard if you decide to buy the glue be carful with the starter pen, it melts the plastic instantly you don't get a second chance, I very rarely use the starter pen as I think you get a better joint just using the glue.
Howard
« Reply #47 on: October 20, 2021, 09:21:47 am »
Thank you Brian I will buy some next time am in town.
                        Regards Howard.
mrzippy
« Reply #48 on: October 20, 2021, 10:30:55 am »
Hi Brian,
While we are on the subject of glues -
I'm interested to know what is used to stick the plasticard around inside of the top of hull/bulwarks?
regards Paul
chipchase
« Reply #49 on: October 20, 2021, 03:47:37 pm »
Hi Paul
I use the same glue for the plastic around the inside of the bulwarks Mitre Bond, I used Grip medium for many years but unfortunately I'm not able to get it know. I did manage to get some from flea bay but it took quite a while to come and i didn't it was the same.
Brian
Pages: 1 [2] 3 4   Go Up
