Author Topic: 40-50mm stanchions with 4mm hole  (Read 452 times)
mmartin1980
« on: October 08, 2021, 12:10:22 am »
As the title suggests, im after some 40-50mm stanchions, single hole - but 4mm hole
any suggestions where i can get these would be greatly appreciated
Thanks!
RST
Re: 40-50mm stanchions with 4mm hole
« Reply #1 on: October 08, 2021, 12:23:14 am »
Hi, round or flat stanchion desired might help. 4mm top hole is quite big, possibly bordering simple brass split pin size and soldering up.  How many do you need and what's it for please?  More details will help in your quest.
RST
« Reply #2 on: October 08, 2021, 02:40:36 am »
Bunkerbarge
mmartin1980
« Reply #4 on: October 08, 2021, 07:04:45 pm »
sounds like a plan, as for what they are for, its for the front railing, im a bit apprehensive about trying to make one and solder the uprights as i can see it going completely pear shaped
« Reply #5 on: October 08, 2021, 07:43:02 pm »
A simple and cheap option for single rail guardrails is to insert split pins into thin brass tube.
mmartin1980
« Reply #6 on: October 09, 2021, 01:55:43 pm »
thats sounds like a plan, just orders some rod, tube and eye screws... wish me luck lol
