Pages: 1 2 3 4 5 6 [7] 8   Go Down
Author Topic: What I've been up to  (Read 40376 times)
Taranis
  • Balne Moor MBC
Re: What I've been up to
« Reply #150 on: August 12, 2022, 03:03:54 pm »
Only 33 degrees today.
Frame complete, now ready for the door and cladding. Then I'll design the roof.
ANDY
Taranis
  • Balne Moor MBC
« Reply #151 on: August 12, 2022, 06:24:40 pm »
Lovely venues Power Stations, spent 33 years working in one  {-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #152 on: August 13, 2022, 02:39:49 pm »
Decision is made for the roof. This will be pent with about 10% slope. A single cover of EPDM that has a 20 yrs guarantee and no seams.
This reduces overall cost and makes the build not exceed the permitted height of 2.5 metres on a boundary.
4x2 rafters at 400mm and 11mm OSB sheet.
I'm going to Pershore again where my engine hobby began so I'm not going to order the steel door until midway through that week. The Scandinavian 125x25 cladding will be delivered on Monday so I'll be popular with the neighbours after a couple of thousand shots  {-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #153 on: August 14, 2022, 04:13:05 pm »
600 centres for 18mm board. Self builds change direction all the time.
Temporary cover as a refuge from any Sun tomorrow as the cladding is fired on
A sample of the cladding
ANDY
« Reply #154 on: August 15, 2022, 08:53:05 pm »
Oooo nice toy Andy  :-))
Taranis
  • Balne Moor MBC
« Reply #155 on: August 15, 2022, 09:00:48 pm »
Yes indeed Phil, today it only missed 4 times in a thousand nails or more.
The cladding arrived and despite my "will do it in day" notion  {-)  It will take another shift tomorrow.
Wednesday I can focus on skinning the roof.
Build cost is going to be closer to 3K given experience and knowledge gained on the way. Materials just keep rising in price!
This is the intended roof membrane and trim kit  https://www.roofingmegastore.co.uk/flat-epdm-rubber-roof-kits.html?abt=1
ANDY
Taranis
  • Balne Moor MBC
« Reply #156 on: August 16, 2022, 07:33:23 pm »
Another very full day has seen the cladding completed.
Focus now changes to the roof.
ANDY
Taranis
  • Balne Moor MBC
« Reply #157 on: August 18, 2022, 08:08:47 pm »
Yesterday the roof edges were fitted
I made a rough plan of the cuts
A couple of trips
The essential glue for the joints
Cracking on
Ready to recover until I get the EPDM kit
The motivation
Super strong shelf from left overs. Possibly four water pumps on there
ANDY
Taranis
  • Balne Moor MBC
« Reply #158 on: September 01, 2022, 08:31:32 am »
Moving on
Latham steel door
Next job is facias and soffits to the roof before fitting EPDM kit
ANDY
Nordlys
« Reply #159 on: September 01, 2022, 03:10:03 pm »
What is the grey flooring material please?
Always  interesting posts.
N.
Taranis
  • Balne Moor MBC
« Reply #160 on: September 01, 2022, 03:15:06 pm »
N.
ANDY
« Reply #161 on: September 01, 2022, 03:29:39 pm »
More curing agent than resin? .... that's unusual?!
Nordlys
« Reply #162 on: September 01, 2022, 04:17:32 pm »
Thought it was some kind of floor cover like linoleum.
« Reply #163 on: September 01, 2022, 04:26:38 pm »
Where is it available from Andy, looks really cool, was it easy to mix and lay ?
Taranis
  • Balne Moor MBC
« Reply #164 on: September 01, 2022, 04:51:30 pm »
ANDY
Taranis
  • Balne Moor MBC
« Reply #165 on: September 01, 2022, 04:56:20 pm »
Problem with such is that without heating moisture developes underneath that can then attack the wood. The whole structure is free to breath currently
ANDY
Nordlys
« Reply #166 on: September 01, 2022, 05:50:46 pm »
Yes, you're quite right Andy. I've been refurbishing my summerhouse and under the old lino flooring, in just one corner I found the floor had given way. Now I know why!
Mind you, it was 25 yrs old at least. The floor that is.
It's not an insulated structure but has resisted the weather,  largely, thanks to Ronseal and Cuprinol.
N
Taranis
  • Balne Moor MBC
« Reply #167 on: September 04, 2022, 05:06:22 pm »
Moving in slowly
Just the roof membrane to fit and the edge up stands on three sides, gutter to the rear.
should last until I'm 115  ;)
ANDY
Taranis
  • Balne Moor MBC
« Reply #168 on: September 08, 2022, 09:45:24 am »
A bad experience with a courier called TUFFNELLS having delivered my order to the wrong address but I managed to retrieve it.
Only the rubber and adhesives arrived but it enabled fitting yesterday
Being quite hot weather it didn't take long to relax ready for gluing
This was then rolled up half way and the water based adhesive applied to the deck all bar a 100mm border, then the other half.
Finally impact adhesive around the edges. The aluminium trims should arrive today.
ANDY
Taranis
  • Balne Moor MBC
« Reply #169 on: September 08, 2022, 07:59:06 pm »
Further issues with Tuffnells today again delivering to wrong address and actually dumped outside a block of flats. So even worse than Yodel.
Just about finished and now making a gate for between the shed and garage.
Straight into neighbours gutter
ANDY
Taranis
  • Balne Moor MBC
« Reply #170 on: September 12, 2022, 08:07:18 am »
I built the gate to create an out of sight outside storage area, its 1200x1800. Instruction video found on you tube.
ANDY
Taranis
  • Balne Moor MBC
« Reply #171 on: October 03, 2022, 07:09:46 pm »
Another one rescued
13th July 1950 Petter W1H
ANDY
Taranis
  • Balne Moor MBC
« Reply #172 on: October 10, 2022, 09:09:23 pm »
Another pump nearly completed.
ANDY
« Reply #173 on: October 11, 2022, 09:23:04 pm »
Really cool Andy, I assume it works well  :-))
Taranis
  • Balne Moor MBC
« Reply #174 on: October 24, 2022, 11:11:21 pm »
Thanks yes it will do when finished. I'm now on my 5th pump with a sixth in waiting
I just acquired pump 6 and engine 7 in one go. This is 1938
ANDY
Pages: 1 2 3 4 5 6 [7] 8   Go Up
