Author Topic: reinforce a hull  (Read 1105 times)
merseyferry
reinforce a hull
« on: October 10, 2021, 03:45:18 pm »
what is the best way to reinforce a plastic hull,i was considering  coating it in pva glue ???? its a billingboats hull feels kind of thin
Umi_Ryuzuki
    • Models and Miniatures
Re: reinforce a hull
« Reply #1 on: October 10, 2021, 04:56:32 pm »
Possibly add additional wood framing, or stringers between existing frames.  :-)
16-21
« Reply #2 on: October 10, 2021, 07:00:35 pm »
You could use
Glassfibre sheet or tissue with west system epoxy
It should be ok with epoxy resin.
Do not use p40 as it will cause damage to the plastic abs hull
« Reply #3 on: October 10, 2021, 07:10:08 pm »
The hull strength is probably OK unless you run it into something pointed at speed! Unless it is actually disrorted and out of shape I would leave it as it is. Don't overthink these things.
RST
« Reply #4 on: October 10, 2021, 09:36:33 pm »
What model is it?  I mainly build in PS but ABS from Billings not much different, the only hull I worry about is a part built Krick WSP47 which is very thin but there must be hundreds out there OK. I'd advise NOT to think about coating the inside, have seen it done and it's a mess and unecesary.  Pretty much what Colin said.
merseyferry
« Reply #5 on: October 10, 2021, 10:27:02 pm »
thank you for your guidance,i will leave it  as it is... its a backert i am attempting to  rebuild once again thank your advice gents
RST
« Reply #6 on: October 10, 2021, 10:59:24 pm »
.....thanks, many banckerts out there do just fine (if not all). There's a build of one here now with great results.
« Reply #7 on: October 11, 2021, 10:30:08 am »
Time-consuming but probably the easiest!   :-))
Page created in 0.132 seconds with 21 queries.
