Author Topic: 14mm glazed Brass Porthole  (Read 576 times)
ukmike
« on: October 11, 2021, 09:38:28 pm »
I need 1x 14mm non flanged  glazed Brass porthole.
It's something that I very rarely use but I need 1 only to complete a project. All that I can find are packs of 10, 9 of which would probably never be used.
Please have a rummage around, maybe someone has one that I can buy.
Mike.
Taranis
  • Balne Moor MBC
Re: 14mm glazed Brass Porthole
« Reply #1 on: October 12, 2021, 08:37:59 am »
ANDY
Youíll only know your best effort if you donít give up.
ukmike
« Reply #2 on: October 12, 2021, 01:11:45 pm »
How do Andy.
Those are the ones, but it looks like I'm having to buy 10 to get one which will be the most expensive 14mm model boat porthole ever  >:-o
Being a Yorkshire man it will break my heart  <:(
Mike.
roycv
« Reply #3 on: October 12, 2021, 01:55:09 pm »
Hi flanged ones were mentioned as not wanted I have not seen any non-flanged.  Bit puzzled.
Roy
roycv
« Reply #5 on: October 12, 2021, 02:52:24 pm »
Lovely picture Taranis and that is what I always thought a port hole looked like.  So what is a flangeless one?  Does it not have the securing holes?
Roy
Taranis
  • Balne Moor MBC
« Reply #6 on: October 12, 2021, 02:53:29 pm »
Non flanged would be welded in place  :-))
ANDY
roycv
« Reply #7 on: October 12, 2021, 02:55:13 pm »
Thanks!  so flangeless ones are going to be like rocking horse doo-dah.
Roy
barriew
« Reply #8 on: October 12, 2021, 03:00:55 pm »
Hi Mike - is this any good? 14.2mm ext 11.8 mm hole
FOC from one Yorkshireman to another  {-)
Barrie
Taranis
  • Balne Moor MBC
« Reply #9 on: October 12, 2021, 03:25:11 pm »
Roy
Readily available in all sizes
ANDY
« Reply #10 on: October 12, 2021, 03:29:04 pm »
If you are fitting it in thin material then you could consider mounting it back to front...
ukmike
« Reply #11 on: October 12, 2021, 11:01:25 pm »
Barrie
Thanks Barrie. PM sent.
Mike.
RST
« Reply #12 on: October 13, 2021, 12:21:41 am »
By the laws of modelling don't you really need 2?  One to use, one to forget and find later and now you remember what it was for, can't find the original one you put in a safe place.  Just as well you got a spare so you can complete the job.  The first one will turn up in a matter of a few hours later after the first is fitted but the gremlins hid it while it was needed.
Tug Hercules Fireman
« Reply #13 on: October 13, 2021, 03:41:05 am »
Recall the Flange goes to the inside, not the Outside.
Tug Hercules
Fireman Rick
ďIdeals are like the Stars; We never reach them, but like
Mariners of the Sea, we chart our course by them.Ē
RST
« Reply #14 on: October 13, 2021, 03:55:05 am »
You guys over there always have a bit of a different perspective on life.  As my cousin in Regina would say: Fair play -but did nobody tell you before?  I'm so sorry.
Actually, if you want to fit portholes from the back then you need only a very thin slip of tube -you just fit glazing of apportionate  sized sheet across the back.  The OP didn't look for this and specifcally asked for a solution of one from a pack of ten easily available so I think the "wanted" post has run it's course if he rfceives the desired package (and hope all flangeless portholes are turned to the same profile and I'm not sure thy are).
Taranis
  • Balne Moor MBC
« Reply #15 on: October 13, 2021, 10:18:19 am »
George Michael style  {-)
To be honest fitting them on the inside never occurred to me and would have looked ok apart from the styrene is a bit too thick.
Thanks for the tip Colin  :-))  and Rich for the further idea  O0
ANDY
