Pages: [1] 2 3   Go Down
Author Topic: RC operated aircraft carrier models  (Read 8950 times)
Backerther
« on: October 27, 2021, 05:31:37 am »
Hi frogman3 ;
Max number of planes loaded aboard the full scale HMS Fencer was I understand were 22 while I have 23 Seafire fighters for my 1/96 Fencer. However,actual number of Seafire I put on the flight deck is 14 for the convenience'sake to get easy access to the inside radio gears at the sailing spot.
1/2;22 planes are set on the flight deck.
3/4/5;When sailing on the water,around 14 planes are suitable to keep an easy maintenance on the shore.
   Moreover,this is not an attack carrier like USS super carriers so that it's rather strange if the planes were loaded fully and I think even 14 planes are rather many for the CVE Fencer,perhaps...? %% {-) O0
6/7;Fighter No1 is now taking off at full throttle and flaps fully down,tail gear up passing beside the bridge, seen off by the crews wishing a safe return.!!!! {-) O0 %% ok2
8;Fighter No2 has also started the engine for take off..The deck is surrounded by so tense an air.... {-) {-) {-)
frogman3
Re: RC operated aircraft carrier models
« Reply #1 on: October 27, 2021, 11:25:54 am »
HI Backether
some very nice pics of your hms fencer   an she is sailing beautifull   an looks real  an  ive been studying them to see the detail an i will say that your model work is brilliant  very well done  :-))
an my NIMITZ pics are all over the show on my p/c SO it will take a few hrs to find the pics as they were all put in a folder as i have all or most of my NIMITZ 7YR BUILD in a folder but for now ive found up a shot of my NIMITZ still in the build stage with my wife  jen holding it hope you like it an there will be more pics to follow later
https://ibb.co/mHbpVYC :-))
chris
Backerther
« Reply #2 on: October 27, 2021, 01:37:54 pm »
Hi frogman3;
Amazingly huge hull,first of all !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :-)) :o O0 {-) ♫~♩~♫~ :o
I can't find any suitable words to express exactly my present impressions when I have just seen the pic.!!!
How I envy you and your space to work for the ship as well as so cooperative and broad-minded wife. :-))
Without such a wonderful wife's cooperation,a great model of RCed gigantic super carrier could not be successfully done...
I am waiting for the pics showing nice sailing on the water like a real ship.!!
frogman3
« Reply #3 on: October 27, 2021, 06:36:58 pm »
HI Backerther lovely pic of you  thank you  :-))  an i will post one of me when i can find it  an here are a few pics of my NIMITZ as got quite a few but i dont want to overload you on pics an the first pic is where NIMITZ is in the test tank checking for leaks an stablity an how much weight will be needed to make her sit propberly in the water
https://ibb.co/XtcNBHG
frogman3
« Reply #4 on: October 27, 2021, 06:44:02 pm »
AN A shot of her up the pond on her display table
https://ibb.co/pntwBVL
frogman3
« Reply #5 on: October 27, 2021, 06:49:42 pm »
an crew figures in her bridges an the whole ships lights up as three elevators all work up an down an the hanger doors all open an close from R/C as does all the lights an 5 working radars  on the mast an the big sp49 on the rear mast near the bridge an the freshnel landing lights all work
https://ibb.co/ZLhNpX6
frogman3
« Reply #6 on: October 27, 2021, 06:51:51 pm »
stern shot of her  an ive still have to fit all the safety railings an such
https://ibb.co/Ld0GCdm
frogman3
« Reply #7 on: October 27, 2021, 06:55:41 pm »
on the water with the front elevator in the down postion an hanger door open as she had aircraft in her hangers as well
https://ibb.co/pb1BBP3
frogman3
« Reply #8 on: October 27, 2021, 07:01:05 pm »
Bow shot an the bridel catches are spring loaded to if it hits the concreate wall of the pond it wont cause an damage
https://ibb.co/2jGbgpP
frogman3
« Reply #9 on: October 27, 2021, 07:04:10 pm »
an some aircraft shots as in my hand a super hornet  in 1/144 scale with nav lights an strobe lights which will be seen in the next shot
https://ibb.co/LtvRM00
frogman3
« Reply #10 on: October 27, 2021, 07:05:13 pm »
frogman3
« Reply #11 on: October 27, 2021, 07:05:46 pm »
frogman3
« Reply #12 on: October 27, 2021, 07:06:54 pm »
frogman3
« Reply #13 on: October 27, 2021, 07:08:41 pm »
flightdeck all with the lights on ready for flight operations
https://ibb.co/rvSnRkc
frogman3
« Reply #14 on: October 27, 2021, 07:10:46 pm »
here aircraft elevator in down postion with hanger door open so that aircraft can be seen in the hanger
https://ibb.co/7GNv0PR
frogman3
« Reply #15 on: October 27, 2021, 07:17:03 pm »
an here my wife jen is on gaurd to stop people touching the carrier as its in a model show but no public in yet as we had just set up NIMTZ for the show very early as it took an hr to fit all the planes on her an they are held on by metal pins fitted in the planes to fit in holes in the flightdeck well that will do for now an if you want to see any more just say an i'll post some more different pics hope you like the pics Sir
chris
https://ibb.co/d5Ts2y9
RST
« Reply #16 on: October 27, 2021, 09:28:24 pm »
Hi Chris,
Yor wife Jen must be long suffering of bits and painting everywhere in the house, you don't need a "please don't touch card" on that!
(No offence intended:  Please don't take it the wrong way -just the second picture you posted of someone looks very commtted to the other halves cause and some very friendly chuckling seeing it)
Superb models in all cases.  Would love to have the patience to make something that size, I would never see it through.  When I was a kid one of my plastic models was HMS Victorious but I was probably pre-teens and made a bit of a mess of it though I had it on the shelf for years until the usual problem with the humbrol plastic cement in tube type dried out and it started to fall apart!
frogman3
« Reply #17 on: October 27, 2021, 10:27:47 pm »
HI Rich yes i get your message an jen is happy an helps me with my build as she has her jewrly making hobby but the stern look she has on her face is because she has an got cancer an not very happy at times as she has good days an bad an on this day at the model show she was not feeling to good  no one eles would be either would they  <:(
chris
RST
« Reply #18 on: October 27, 2021, 11:11:40 pm »
Oh no, Chris, I didn't mean that (PM'd)! Credit to both of you.
frogman3
« Reply #19 on: October 27, 2021, 11:16:53 pm »
HI Rich no worryies
CHRIS an jen
frogman3
« Reply #20 on: October 28, 2021, 07:20:16 am »
HI again Backerther
hope you liked the pics of my NIMITZ an i will post some more pics of her if you want  an ive been studying your pics of your HMS Fencer an the detail is fantastic on her an i really like your seafires as the one taking off looks real this is a very well made model Sir very well done indeed  :-)) an how long did it take to build ?
chris
Backerther
« Reply #21 on: October 28, 2021, 01:52:41 pm »
Hi frogman3;
First of all,I am awfully sooooory to be late in replying to your postings that include many marvelous pics of USS Nimitz 1/144. I am a part time worker who works 2-3days a week and got back home one hour before today ,though I am too old now. And I have been watching your pics now in detail and they looked really magnificent every inch the USS Nimitz.!!! O0 {-) :-)) :-)) :-))
"Stunning and exceptional work of model ship in every part of the carrier "is my impression.!!!
My HMS fencer is a model ship while your USS Nimitz is a real ship merely scaled down to 1/144.!! {-) O0 %%
In other words,I am a model ship builder while you are a shipwright. I am correct, amn't I, sir??? {-) %% ok2
1/2;Diesel engine sound unit, while actual main engine of the full scale carrier was steam turbine.!!!!!! {-) {-)
3;Ballast test using 2.3m swimming pool.
4;HMS Fencer 1/96 going back to Greenock for maintenance....?? {-) {-) {-) ok2
frogman3
« Reply #22 on: October 28, 2021, 02:28:11 pm »
HI Backerther
AN glad you liked my NIMITZ pics  many  thanks  but i like your fencer as its very nicely detailed an i love your seafires SIR they are some bueatifull planes an again very well detailed so all in all we both have have some very nice models  an your model fencer is every bit as good as my NIMITZ its just that my model is bigger but we are both model ship builders an very good they are too
CHRIS an ps may i have your first name if possible but if you dont want to give it thats ok an have a nice day
chris  :-))
frogman3
« Reply #23 on: October 28, 2021, 02:34:34 pm »
HI AGAIN
REGARDS YOUR PICS is the first pic a tamyia sound unit ? an i love your deck on your fencer it looks like wood plankin very well done sir she sure is a bueaty of a model very well done an how long did it take you to build ?
chris
Stan
« Reply #24 on: October 28, 2021, 06:17:39 pm »
Hi Frogman3 hope you enjoy this link to Gambier Bay. This link is a very comprehensive look at my build over the years.
Stan. :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-))
https://www.modelboatmayhem.co.uk/forum/index.php/topic,59698.msg626675.html#msg626675
Pages: [1] 2 3   Go Up
Page created in 0.029 seconds with 21 queries.
