Author Topic: 71" (1.8m) TID Tug Build (Cont'd!)  (Read 11999 times)
tizdaz
  • Boom!
    • My RC TID Build
« on: October 29, 2021, 02:19:42 am »
Hi guys,
I Decided to start a new thread for my build as my previous thread have broken links to all the images :(
...sooo to kick it off, My electric board is pretty much done, but I'm going to be adding a P103 Parallel Power Board to bump up the capacity for longer run times.
Here's a few pics, I've done a dry test & connected everything up & ran it as I would for a good 40+ mins constant, everything seems good (touch wood!) the 2 step up converters barely get warm which is a bonus! will add some vid tommoz, I have to say, the BIER sound module is a top notch piece of kit, its a lot more than just a sound module! ..takes a little getting to grips with the software as there's hundreds of options for lights/fans/sounds etc!
Will take some vid tommoz, I'm pretty happy with the outcome, took a while to complete but worth it i think, Next on the agenda is to complete my second take on the stack (my 1st attempt was good, but the stack was slightly too large! so i made a start on a new one.
Wiring Diagram:
Test #1
Completed
My large-scale TID Build Website:
http://www.tizdaz.co.uk
Facebook:
BrianB6
Re: 71" (1.8m) TID Tug Build (Cont'd!)
« Reply #1 on: October 29, 2021, 06:30:55 am »
Nothing beats Perspex for mounting electronics.  O0
tizdaz
  • Boom!
    • My RC TID Build
« Reply #2 on: October 29, 2021, 06:55:02 am »
indeed!
the perspex i used was clear, so gave it a coat of black from the underside, did the trick! :)
Facebook:
« Reply #3 on: October 29, 2021, 10:00:37 am »
Oh yes it does, Paxolin (Tufnol - SRBP or F) isn't subject to static charges.
tizdaz
  • Boom!
    • My RC TID Build
« Reply #4 on: November 01, 2021, 02:52:12 am »
Wheel almost done, made from scratch using wood & some thin brass rod, gave it a coat of stain/varnish going to give a couple of more coats & tidy it up with a little sanding :)
Last pic has an AA battery in view for size comparison,
Facebook:
tizdaz
  • Boom!
    • My RC TID Build
« Reply #5 on: November 14, 2021, 10:42:19 pm »
Electric Board/Box complete :)
Finally finished my electric box :D
i made this box using bits of ply & Perspex, I also decided to fit a 12v fan to the case that i had laying around to help keep the temperature inside the case low. The fan is connected to the Beier USM-RC2 module & I have programmed the module so the case fan operates at 60% & it will also automatically switch off if there has been no signal from the TX after 1 min. It will automatically turn on again as soon as there is a signal again from the TX (Such as forward on throttle or light switch etc). I decided to use pluggable terminal blocks, these are pretty neat & will allow me to insert/remove the electric box with ease :) The two servo extension wires you see are for the Rudder servo lead & the main power switch which i will be fitting somewhere above deck but hidden for easy access to turn the model on/off, I will probably fit the power switch under one of the engine room hatches.
Next the Agenda, is to cover the deck with some filler & also some UPOL Dolphin Glaze as recommended to me by someone in the know! & get it ready for painting along with the hull.
Facebook:
tizdaz
  • Boom!
    • My RC TID Build
Re: 71" (1.8m) TID Tug Build (Cont'd!) (Updated: Electric Box Complete!).
« Reply #6 on: November 14, 2021, 10:55:05 pm »
oh yeh, also heres new diagram as ive added a P103 and made a few other tweaks etc!
Facebook:
TheLongBuild
  • Build em, and play hard..
« Reply #7 on: November 15, 2021, 08:25:21 am »
That's a flipping micro pc  %% %% %%
« Reply #8 on: November 15, 2021, 08:25:30 am »
             Impressive design, implementation!    :o
tizdaz
  • Boom!
    • My RC TID Build
« Reply #9 on: November 15, 2021, 09:10:54 am »
lol cheers guys :)
when it comes to electrics/wiring i have OCD i think! even though i will very rarely see it as its tucked under the deck, i still want it to be neat & tidy lol :D
Facebook:
TheLongBuild
« Reply #10 on: November 15, 2021, 11:13:48 am »
Like the self destruct plunger on the top.. :}
tizdaz
  • Boom!
    • My RC TID Build
« Reply #11 on: November 15, 2021, 05:22:23 pm »
i actually felt like self destructing at times while trying to make it! lol
Facebook:
« Reply #12 on: November 15, 2021, 07:08:48 pm »
Why two BUCK 24v converters?
NB: If you still have the images from the previous thread Daz, I'll happily re-add them for you.  :-))
       https://www.modelboatmayhem.co.uk/forum/index.php/topic,56353.0.html
tizdaz
  • Boom!
    • My RC TID Build
« Reply #13 on: November 15, 2021, 07:26:50 pm »
NB: If you still have the images from the previous thread Derek, I'll happily re-add them for you.  :-))
im using 2x mist units so decided to use 1 converter for each mister :)
Facebook:
« Reply #14 on: November 16, 2021, 12:56:11 am »
....'images from the previous thread Derek'....
do you mean DAZ.... Martin?
tizdaz
  • Boom!
    • My RC TID Build
« Reply #15 on: November 16, 2021, 01:00:40 am »
i do have them, but no idea what ones are missing from which post etc & i have lots (100's) of images :(
Facebook:
tizdaz
  • Boom!
    • My RC TID Build
« Reply #16 on: November 16, 2021, 01:01:06 am »
Facebook:
tizdaz
  • Boom!
    • My RC TID Build
« Reply #17 on: November 22, 2021, 12:45:58 pm »
Deck is now fixed in place & added the coaming, the coaming was fixed in place by screws & also some Titebond III wood glue. The coaming will be covered in Body filler/dolphin glaze when i do the deck to give it a nice finish & watertight seal.
so she's now ready for the deck to be filled using this stuff:
Big Boy Ultra Fine Body Filler
& then i will use this to finish off:
I also fit some Ferrules to my cable ends for the pluggable terminal blocks, I bought the tool from Ebay, and have to say it works perfectly, i tested out the fit by trying to pull the ferrule off with force using a pair of pliers, no chance! it was well & truly fixed on, the crimp tool kit cost just over £14 and that was with 1200 connectors of various sizes (AWG 10 through to AWG22) delivered!
So next will be filling the deck & finishing it off so i can then get on with the Superstructure build! :)
Facebook:
tizdaz
  • Boom!
    • My RC TID Build
« Reply #18 on: November 22, 2021, 01:05:30 pm »
Finished the new stack!
The old one was slightly too big so i remade it & now its exactly true to scale, i just need to complete the top/bottom of it & the details etc!
The one on the left is the OLD one compared to the new one on the right side :)
They were both made using planking & some plumbing tube for the centre with wooden/plastic discs as spacers.
Facebook:
tizdaz
  • Boom!
    • My RC TID Build
« Reply #19 on: December 16, 2021, 01:05:25 am »
righty!
So I've almost complete new stack, just got to finish off the top of it & then paint it, the colours will be green body with a dark/racing green top section to match what the hull green colour will be.
I've also added a couple of shelves at bottom of hull to place the ballast tubs, just need to add a couple more shelves to the forward & aft of the hull. I'm hoping (if my calculations are correct!!) that the ballast tubs which will total 25kg & then the 4 SLA's which total 25kg along with the superstructure/electric board and all the other bits & pieces etc that this will be more than enough to ballast her :)
Ballast Shelving:
Facebook:
tizdaz
  • Boom!
    • My RC TID Build
« Reply #20 on: December 16, 2021, 01:09:12 am »
for some reason images when i post them are sometimes loading & other times they are not!?
just happens randomly what images the page will load?
Facebook:
tizdaz
  • Boom!
    • My RC TID Build
« Reply #22 on: January 13, 2022, 01:51:33 am »
filled deck using Big Boy Ultra Fine 2-Part filler & then a thin coat of U-Pol Dolphin Glaze, Yes my filling skills are not great, but end result I'm happy with and deck feels solid. Once Bulwark supports are all in place i will then be using some high build primer to cover the whole bulwark area & supports.
I also trimmed the top of bulwark edge to give equal width right the way around.
Making a start on the Bulwark supports now, at first i was going to use 5mm ply but someone mentioned that 3mm would be more scale so im using 3mm ply now! It's a VERY time consuming process as every support has a slightly different shape so using a template to make all of them isn't possible. I still need to make about another 30!
After the Bulwark supports are completed i will then fix them in place then i will make a start on the deck planking :)
Facebook:
nemesis
« Reply #23 on: January 13, 2022, 03:13:27 pm »
dont forget to cut the corner off the stay, deck to bulwark. lets the water run through. nemesis
Ralph
« Reply #24 on: January 13, 2022, 09:46:32 pm »
Makes the supports easier to shape and fit as well since you don't need to worry about matching any fillet between the deck and bulwark.
Ralph
